Tilt won't hold
Hey I am having a problem with my tilt on an old clark I tilt the mast back let off and she goe right back forward Ireplaced the o rings in the valve body but still same problem?
  • Posted 1 Sep 2010 23:58
  • By Hammerzin
  • joined 22 Aug'10 - 5 messages
it is most likely your tilt cylinders need to be resealed just like the previous person said, had this happen to one of our old clarks
  • Posted 3 Sep 2010 04:04
  • By liftfixer
  • joined 6 Mar'08 - 6 messages
it happened all the sudden really
  • Posted 2 Sep 2010 12:03
  • By Hammerzin
You could also have a faulty tilt relief valve. Did this just start happening? was it a gradual failure or all of a sudden?
  • Posted 2 Sep 2010 08:46
  • By steponmebbbboom
Chances are the fluid is bypassing in the tilt cylinders. They either need to be repacked or I have also seen a void between the rod and the piston that holds the packing that seals against the shell that lets the fluid bypass.
  • Posted 2 Sep 2010 01:11
  • By duodeluxe
  • United States
duodeluxe
SMV (Konecranes) SL37-1200A
Morooka MFD20
Linde Material Handling
Morooka MFD20
