Error 124 and 24
Hello friends, I have a problem with this machine, the right motor controller module broke. The model is replaced with a repaired one and the machine gives these errors, 124 and 24, I load the basic settings and the settings of this type of machine that Judit provides me and the errors continue, the machine has all the lifting functions but the Front wheels turn in the opposite direction from each other. Thank you very much in advance for your help.
  • Posted 7 Aug 2024 21:05
  • By NICOGRAO
  • joined 3 Jul'24 - 8 messages
  • Spain
Nico
Yes, totally true, you are absolutely right but there is no possibility that that could have happened. Furthermore, you would not have errors 024 and 124 as soon as you turn on the machine.
  • Posted 26 Aug 2024 05:38
  • By NICOGRAO
  • Spain
Nico
If you think about it, it's logical that either connections are wrong, or the machine thinka left controller is for right, and right controller is insralled for left, as opposite motors are facing opposite directions.
  • Posted 23 Aug 2024 01:40
  • By Tanel_M
  • joined 18 Jun'22 - 90 messages
  • Estonia
I can't have been wrong. The cables are sealed in an orderly manner from bottom to top from shortest to longest. I don't understand anything, I have changed this type of plates many times and I have never had this problem.
  • Posted 21 Aug 2024 23:04
  • By NICOGRAO
  • Spain
Nico
Are the power connections (U,W,V)of the front left/right motors correct?
  • Posted 8 Aug 2024 22:07
  • By Tanel_M
  • Estonia
