Steering potentiometer
Hello everyone. I have a problem with forklift bt (cesab blitz). After replacing the rear wheel turning potentiometer, it needs to be calibrated. I know that i need to enter the service menu to perform the calibration. In this model there are only 2 buttons under the steering wheel (turtle and lph), there are no buttons on the display. I am asking for help or information on how I could calibrate correctly.
Please help.
  • Posted 7 Dec 2021 06:05
  • By Daniel_Dengee
  • joined 7 Dec'21 - 5 messages
  • Poland
Hello, forklift still does not cooperate after a few days of testing. Anyone have an idea what might have happened? the inverter is broken or does the potentiometer just need to be calibrated by the handset? I will add that the error appeared while driving in a cold store (it drives in normal conditions on a daily basis)
  • Posted 9 Dec 2021 17:00
  • By Daniel_Dengee
  • Poland
janu122 (at) gmail (dot) com
Thanks for the information. Earlier, I changed the potentiometer and set it with an ohmmeter in the middle and the error 28 (KO steer sensor) was still displayed. The wires from the potentiometer to the inverter are good. In addition, the forklift has a limited speed (as if it were riding a turtle) and the microswitch does not activate the second and third sections of the control valve (the wires are also good). I wonder if the forklift will behave like this if it is in safe mode. Maybe the inverter zapi logic broken?
  • Posted 7 Dec 2021 16:57
  • By Daniel_Dengee
  • Poland
in a pinch, you can manually calibrate if you cant access dash. First, you needed to really center the steer wheel. With an ohmmeter, get pot centered as best you can. this gets you pretty close. With drive tires in air, run in forward then steer all the way left. Left wheel should stop or turn in reverse. Do right...if same you're good to go. If you are not centered, a hard turn may force the inside wheel to aggressively turn. This can blow a controller.
this adjustment depends on how EASY the steer pot is to access. Last Hyundai i did needed counter weight removed! I did adjustment manually as i could not access calibration settings
  • Posted 7 Dec 2021 12:18
  • By Bluenose
  • joined 2 Apr'14 - 31 messages
  • Nova Scotia, Canada
Take me as i come, cause i can't stay long....
