Stall under load
Hi all I have a Hyster S2.50XL around 2005-2010 I think, running on gas.
She's stalling whenever the hydraulic controls are maxed out, whether it be steering, tilt, side shift or lift it just stalls.
Looks like there is a system on the Hydraulic pump that is linked to the carburetor to increase the idle. How does this work and what usually goes wrong with this?
Hoping to get some info before going through a repair shop as they are all flat out and booked out for 3 weeks or more.
Thanks
Paul Mac
  • Posted 15 Feb 2022 17:03
  • By PMac
  • joined 15 Feb'22 - 1 message
I would suggest you check pressures on the hydraulic pump if all functions are causing it to stall. Is engine idle speed correct? If it is to low, the engine will stall. Because it is a gas engine, check the timing also.
  • Posted 18 Feb 2022 08:05
  • Modified 18 Feb 2022 08:06 by poster
  • By meliftman
  • joined 31 Jan'12 - 209 messages
  • Alabama, United States
Liftman
Retired
Elberta, Al.
Taylor T520M
Taylor T520S
Taylor T520M
Taylor T520S
Taylor T520M
Taylor T520S
Libiao Robotics
