going back a little ways try dash dss 2 xxxxlast four in the s/n or 2enter
Thanks Mike, I will give it a try.
Sorry to cut in like this, but I have a Raymond DSS300 unit that had the lift potentiometer replaced and now I can't get into the system to relearn the new sensor, any assistance would be greatly appreciated, thanks.
6R fault code Lift circuit dtect open. Check C3 capacitor on the lift control heatsink--Bad REC5 on the lift control heat sink-=-The lift motor could be shorted internally or shorted to frame. iF iM NOT MISTAKEN THE LIFT HEATSINK ASSY IS SOLD AS ONE UNIT THRU RAYMOND AND DEPENDING ON YOU YEAR MAKE, MAY HAVE BEEN AN UPDATED PART THRU THE FACTORY.
