popping sound from the internal battery charger
we just installed 4 new batteries but when the blue lever is pulled up so that the batteries power is activated there is a popping like sound, like a solenoid going off. The charger needle jumps when this happens also. We tried the fork lift and everything works, but it keeps doing it unless we push the blue lever down to disconnect the batteries. Any help?
  • Posted 20 Sep 2014 08:01
  • Modified 20 Sep 2014 08:02 by poster
  • By page_p
  • joined 20 Sep'14 - 1 message
you may need to get someone with experience in these units (or an electric forklift tech with a schematic) to check your battery hook up. this is not so much a 24 volt truck as a 2 section 12 volt truck that can use both 12 volt sections together as 24 volts for a faster travel speed.
my bet about the 'popping sound' is that you are blowing the circuit breaker inside the charger, and if you let it go, it will blow/burn out the circuit breaker.
  • Posted 20 Sep 2014 22:46
  • Modified 20 Sep 2014 22:48 by poster
You have to have the disconnect lever up and connected or else both sets of batteries will not be connected to the charger. What happens if the lever is up and THEN plug in the charger? How high does the needle go up? Does the needle stay there? Where is the pop coming from? Does the charger pop and then the needle drop down?
  • Posted 20 Sep 2014 08:46
SMV (Konecranes) 20-1200B
Maxlion MTF30-45-2WD
Hyster
