No power to operate lift or driveu
I'm trying to figure out what is wrong with the boom lift. The operators told me it would operate for a few minutes then stop then they would have to power down and up again to get the lift to function. As time went on the function time got shorter until it wouldn't power up at all. If you play with the key switch turn on to basket or base you can get a slight powering up chirp and the controller light would light up for a split second. Power is going to the controller and there are no blown fuses or tripped circuits. I don't want to just replace the controller if it could be something I'm missing. Any help would be appreciated. Serial #0300074305
  • Posted 28 Feb 2020 12:08
  • Modified 28 Feb 2020 12:09 by poster
  • By BigAl73
  • joined 9 Aug'19 - 18 messages
FIXED------
I sent the lift to JLG. The power destitution board was found to be dead.
This was the main power supply board. Replaced that and everything worked expect the jib movement. They used the scan tool to reprogram that function.
-----JLG® Electric Powered Mobile Elevated Work Platform (MEWP) Drive Power Control Module
https://onlineexpress.jlg.com/parts/electrical/electronic-control-modules/p/1600292
  • Posted 6 May 2025 03:18
  • Modified 6 May 2025 03:18 by poster
  • By Tyler_r
  • joined 28 Jan'25 - 2 messages
  • Michigan, United States
BigAl What was the issue? I've got the same lift with the same issues
Thanks Tyler
  • Posted 28 Jan 2025 02:13
  • By Tyler_r
Did you find it the problem on your lift? Sounds like a battery issue. They might be dry. A lot of the time when your machine run time decreases, it's because of lack of acid levels in the battery.
  • Posted 30 Dec 2020 14:53
  • By Scissor_God
  • joined 30 Dec'20 - 26 messages
Scissor God
Shadow722@live.com 209-846-5836
Maxlion R2D35
SMV (Konecranes) 4632CC5
Maxlion R2D35
