Cat Lift Trucks (& Caterpillar) DP 30:
no hydraulics or power steering
the Hydraulics will not fuction and lost power steering, changed control board no change,
mini lever hydraulic controls
  • Posted 25 Apr 2014 19:11
  • Discussion started by bunkerbob
  • Wiltshire, United Kingdom
have you tested for ANY hydraulic pressures? am I correct in thinking this unit has an internal [to the bell-housing] chain drive for the hydraulic pump? the "pressure switch on the spool block" should be for cutting out hydraulics (but not steering) when no one is on the seat, but if you are loosing steering, I would bet it is related to the steering [bottom of the hydraulic control valve, A.K.A. 'spool block'] pressure relief valve, if not the pump.
  • Posted 16 May 2014 20:11
  • Modified 16 May 2014 20:16 by poster
  • Reply by edward_t
The Cat has no steering or hydraulic controls, would this be down to preassure switch on spool block?
We have changed pump, this has no affect, checked the hydraulic tank all good,
Any advise would be appreciated
  • Posted 16 May 2014 00:13
  • Reply by bunkerbob
Model DP30
Serial 7BN10033
  • Posted 25 Apr 2014 20:23
?full model and serial number?
  • Posted 25 Apr 2014 20:07
  • Reply by edward_t
Ncn 110TH
Ncn 110TH 2023
Linde C4230TL5
