hey tinhtinh, faultcodes aren't Always the same it's depending on the type and model. if you can give me the model and serial number I can look it up.
Regards
Marcb
hi marc b
I have a truck FBR15. it failed C23 and eventually I had to replace the controller box.
hi marc b
please can u tell me what is the price for IGBT type:FM600TU-07A.
and from where i can buy one.
thanks for your assistance
thanks marc you really helpfull thanks again
best regards
Hey Muftah; ok the battery on the display board (print card under the display) must have a voltage of 3,4 to 3.6V. if the battery voltage is to low the truck doesn't start up (main contactor doesn't close).
On the same display board you have blue coloured switch (marked RS1) normally it must be on 0. turn it to 5 with the contact off, switch the contact on the display will show the language now you can change it by the button + or -. Ones you made the setting switch of the contact and put RS1 back to 0.
kind regards
marc b
thanks alot marc you give me the start point but i would like to ask you about the small battery in the electronic card in the disply system ,and how i can change the language of the display cause it is not english maybe japan.
thanks and best regards
hey Muftah,
B14 accelerator error
C21 IGBT of the Hydraulic function
C23 microswitch of lift functions
kind regards
marc b
