Need help with mazda 2.0fe cylinder head, asap pls
Have a quick question and i dont have model number at moment, someone might be able to answer, my question is the 2005 fork lift engine says mazda 2.0fe on valve cover, its a lp engine , they need this forklift asap and it has some burnt valves and no compression, my question is I can get a new cylinder head local for a i think Mazda b2200 truck in stock 2 hrs away, im thinking the valves and seats for lp are possibly different but maybe not, does anyone know if this would work? It looks identical looking at pictures, I found on internet someone saying there the exact same but I was also told there not by a parts guy, id love to be able to grab this head instead of waiting 8 days. Its also 400 dollars instead of 1k , any info is much appreciated. Thank you!!!
  • Posted 26 May 2023 15:41
  • By Rich_myers
  • joined 26 May'23 - 1 message
Rich myers
I read your post the head should work if you were thinking to install a crankshaft l would say no they used long and short cranks but the valve in propane are the same as years ago forklifts were on gas and people converted them to propane and if you think about it you can order a forklift on dual fuel.
  • Posted 11 Dec 2024 10:35
  • By Scott_
Scott
I have the same question.
My F2 Mazda in a GLP060TFNUAE093 needs replacement.
Thoughts?
  • Posted 9 Dec 2024 01:09
  • By Albano_Sivart
  • joined 9 Dec'24 - 1 message
  • Alabama, United States
Combilift Ltd
Combilift Ltd
