Mitsubishi FG40K No Start
Model FG40K
S/N AF29C20310
First off, unit is dual fuel. Went to bring it in the shop today so i can rebuild a mast cylinder. Found a crank/no start concern. it tries to start and even smells like propane from exhaust some. Even though it has a full bottle, I swapped just in case. same thing. crank/no start. Even thoughi didnt see any obvious selector switch for fuel, I added a few gallons of gasoline in case it was empty. Still crank/no start. Has spark. Seems to be getting some fuel given I can smell what appears to be propane in the exhaust.
Any suggestions? Is there a fuel selector switch hidden somewhere so i can run it off gas only or at least try to?
  • Posted 12 Mar 2016 02:05
  • By thomas_l
  • joined 15 May'14 - 6 messages
We're an EQUIPMENT COMPANY, run by EQUIPMENT PEOPLE.
Where others stop we continue.
Not sure exactley where on your truck the switch will be located but places to look if it still even has one(if it hasnt been removed by someone and converted to straight lpg only)....is there a switch on the dash??...other places are to the rear of the truck close to the radiator support or on the sides...as for the no start...because you smell propane i would check to see if it is getting to much propane PSI..sounds like the vaporizor may need rebuitl..if it is the impco vaporizor the fuel psi should be around 2-3 PSI coming out of the vaporizor and to the carb(air/fuel mixer).....
  • Posted 12 Mar 2016 03:08
  • By kevin_t
Unicarriers FD80-2
UN Forklift FGL18T
September 8-9, 2026 - Barcelona, Spain
November 11-12, 2026 - London, United Kingdom
February 8-10, 2027 - Mumbai, India
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
