Mast damage Komatsu
photofile dot ru/users/ramazan/115820325/139183559/
I need to repair crook mast inner for Komatsu FD160E-6 for 4,5M mast. Serial number 37E7DD3450.
Who can help me with technical information of the geometry of that truck?
  • Posted 20 Aug 2010 01:59
  • By vladimir_t
  • joined 18 May'10 - 14 messages
  • Zaporozhye, Ukraine
Thanks a lot for the answer! I will write to your email.
I dont have whole mast, only inner section. We can repair it by local heating without the help of any press machine on our crane building plant. So we need only technical information of the geometry 0f the mast.
  • Posted 21 Aug 2010 20:45
  • By vladimir_t
Vladimir t
I do not know the machine but the settings are similar to all.
1st - we have to see the height of the mast below the ground, varies from 15-20 cm.
2 - see the support in the heats of the gap width between bearings.
3 - Watch the height of the maximum tilt forward and backward through the course of monkeys tilt for placement of the pins that secure the monkeys to the mast.
4 - see the maximum width of the mast and rotated between working width of monkeys tilt.
5 - see calculations for the dimensions of the profile or profiles to be used according to the tonnage or cargo maximum permitted according to the manufacturer of the profile to be used.
6 - do not forget the return valve in monkeys lift to descend gently, for without this was catastrophic. with a photograph or drawing of what you want I can help in any way, since I have done some things
my mail: alberto.martins54 @ gmail.com
  • Posted 20 Aug 2010 08:02
  • By AMartins
  • joined 8 May'10 - 107 messages
  • vila nova de gaia, Portugal
Sorry, who can help me with technical information of the geometry of that mast? Any ihformation can help me.
  • Posted 20 Aug 2010 02:03
  • By vladimir_t
Terberg YT222
TCM FHD105Z
REPOWERTEK Inc
Terberg YT222
TCM FHD105Z
