Komatsu 4d95s engine running trouble
Hello everyone first of all I'm new to the forum. I'm a forklift dealer in th UK.
I have a FD 25 with an 4D95s motor. It's recently had reconditioned injectors, new rings and honed bores. With the new head gasket fitted, skimmed head and valves adjusted I started it up to find it ran poorly and struggled to rev up. I cracked the injectors and found that cracking no.1 made no difference to the engines running which suggested the problem being on that cylinder. When number 2, e and 4 were cracked the engine cut out. I compression tested 1 and 2 which had pretty much the same reading. I swapped 1 and 2 injectors around and the same problem.
Any suggestions? Also the fuel stop solenoid doesn't work and is stopped manually by cable.
Thank you.
  • Posted 20 Oct 2015 07:33
  • By kelvin_h
  • joined 20 Oct'15 - 1 message
  • Beds, United Kingdom
JLG G12-55A
Terberg RT223
