is the motor actually getting hot?
on VM jpc10-1,2 and 3 is temperature sensor input, jpc10-23 is gnd for sensor. pretty simple circuit. with sensor connected and ohming out on the pins i listed above resistance should be 800-3000 ohms.
if you need more info let me know..
I can not duplicate the issue and only going off what the operator tells me. Will check the negative cables next time I have the unit in front of me. Even in my 20 plus years of doing this there are still item like this that stump us :)
Thanks
Check the negative post, where they all tie together. May have bad crimp in connectors and eyelets. When code is not on, wiggle harness gently, one section at a time. Rarely the actual heat sensor fails. Common problem are the connectors or a broken wire
you sure thats a 6G?
look again and make sure it is not a 6C.
