hydraulic pump leaking
hey guys,
I've got a toyota 7 series FGU45 that's been leaking from the OUT port of the hydraulic pump. I've replaced the o-ring and cleaned/checked the surfaces, but it's still leaking. any ideas on what the problem is?
  • Posted 30 Aug 2017 06:12
  • By cheez890
  • joined 28 Jul'17 - 13 messages
  • Arizona, United States
You will need to provide a serial number there are several versions.
  • Posted 14 Sep 2017 03:20
  • By Partsguy5
any chance you know how to find the part number for the pipe on the out port of the pump?
  • Posted 14 Sep 2017 01:57
  • By cheez890
I've also found the back plate of the pump, where the fitting screws in, cracks. You can buy just that plate rather than a whole pump to fix it.
  • Posted 31 Aug 2017 20:19
I found the cause of the leak was a failed weld on top of the pipe
  • Posted 31 Aug 2017 06:43
  • By cheez890
Taylor T520M
Maxlion MTF30-45-2WD
