hard moving in reverse, forward moves fine
When lift put into reverse it feels like brakes are locked on, yet when put in drive it moves fine. have no experience with this lift as far as maintenance so any help or links to articles would be greatly appreciated
  • Posted 9 Jun 2018 00:52
  • By SPNC
  • joined 9 Jun'18 - 1 message
  • Wisconsin, United States
firstly i would make sure the brakes are actually releasing completely
check the park brake tension and make sure it is releasing
check the wheels, jack it up by putting chock blocks underneath the mast channels and tilting forward so it will lift the drive wheels off the ground and see how it operates.
make sure the lift is stable before starting work after elevating it
try deadjusting the wheels and see if this problem changes
you might have problems inside the wheels like loose backing plates or broken hardware inside the wheel hub(s).
if you do not find any problems in those areas then look for a transmission control valve problem or an internal problem inside the transmission.
  • Posted 10 Jun 2018 00:24
May CapEx Index falls Washington, DC, United States
edition #1289 - 9 July 2026
In this week’s Forkliftaction News , we continue our coverage of CeMAT Australia with a report on how the lack of local after-sales support and service is hurting new foreign entrants into the Australian market... Continue reading
Tampa Florida, United States
Still GX10
Still GX10 2000
Poland
EUR950
Terberg RT223
Still GX10
Still GX10 2000
Poland
EUR950
Terberg RT223
