fuel regulators toyota 8fgu30
after i have replaced the fuel regulator the on the unit is hard to start and it dose not want to idle under load
  • Posted 27 Apr 2017 08:46
  • Discussion started by freemanrick
  • Arizona, United States
Does this have the GM Vortex engine or Toyota engine?
  • Posted 29 Jul 2017 20:36
  • Reply by Mbrunner
  • Manitoba, Canada
Make sure you coolant levels are up. you have to bleed the cooling system. 8mm bleeder on top of water pump
  • Posted 14 Jun 2017 22:18
  • Reply by Prentice
