Excessive fuel through system
Clark c500-s30 getting excessive fuel at carburetor. Believe it's vaporizer but need confirmation
  • Posted 19 Sep 2022 10:02
  • By William_Few
  • joined 19 Sep'22 - 3 messages
  • Kentucky, United States
William Few
If i remember it is 5 to 7 psi at the water jacket vaporizer
  • Posted 23 Sep 2022 02:26
  • By stillworkin
  • joined 2 Nov'18 - 96 messages
Thanks everybody for info. It was the vaporizer
  • Posted 20 Sep 2022 12:02
  • By William_Few
William Few
Does the vaporizer go into the top water housing where the top hose goes if so it is a zenith vaporizer there is a allen screw at the top that is were you check the gas pressure it is around 8to 12psi any more and the vaporizer is bad also the carb could cause to blow gas through must check at vaporizer first hope this helps.
  • Posted 20 Sep 2022 11:59
  • By Scott_
Scott
A specific vaporizer that goes on. must make 20 psi for it to run correctly. Waukesha engines only.
  • Posted 20 Sep 2022 05:17
  • By grant_c
  • joined 12 Aug'16 - 27 messages
  • Manitoba, Canada
