Error E-152
Our pallet jack will hold a charge and gives the Error message of E-152. It is only about 20 months old so the warranty has expired. Does anyone have information on the code?
  • Posted 21 Dec 2017 04:44
  • By Fann
  • joined 21 Dec'17 - 1 message
JFann
this kit does away with the white plastic tab and has you install the new harness with a strip of wire loom. p/n 1341147/001
  • Posted 5 Aug 2021 00:34
  • Modified 20 Jul 2023 22:25 by poster
  • By Triggs
Same harness got torn on a Toyota 8HBW23 (raymond) ,, with the little curtis AC motor controller, "1232e",,, same exact part numer 1283206/001 in the harness as well.. Thank you the confirming. I had same code Error E152 after boot showed on small display. Also no line contactor closing at all. Just the error.... ??????
  • Posted 4 Aug 2021 03:36
  • By AL_Ultra
  • joined 4 Aug'21 - 1 message
Keep it 100
FOUND SPRING IN HANDLE CUTTING WIRE HARNESS. PART NUMBER ON TAG WAS 1283206/001
  • Posted 22 Jul 2020 22:49
  • By VIPER
  • joined 9 Feb'11 - 24 messages
  • FLORIDA, United States
had the same problem look at the ribbon wire on the card not the one for the key pad.
  • Posted 4 Mar 2020 00:05
  • By justme
  • joined 23 Jan'08 - 19 messages
E-152 CAN Bus Communication Error
Check wiring and battery condition. The Vehicle Manager isnt seeing the heartbeat signal from the traction amp.
  • Posted 21 Jan 2018 04:54
  • By mjohnson
  • joined 21 Jan'18 - 14 messages
  • Wisconsin, United States
Maxlion FD50T
Ncn 85TH
Ncn 85TH 2014
Yale Lift Truck Technologies
