Error Code H?? Cat 2EC30
I am working on a Cat 2EC30 I have Error code H on the dash display.Truck wont move no Hydraulics b/u alarm sounds. I have gone threw the service manual and have found no information on this Code. This unit has MicroCommand II Controler in it. Any help to get me going in the right Dirrection would be Great Thank You
  • Posted 10 Mar 2011 02:01
  • By ryan_r
  • joined 10 Oct'10 - 8 messages
Thank You Found the problem and fixed
  • Posted 11 Mar 2011 03:47
  • By ryan_r
H codes generally refer to a hydraulic switch being closed when starting the unit up. Newer units are followed by a number such as H1, H2, etc......which tells you which switch it is....H1= Lift switch H2=Tilt switch....etc.......
  • Posted 10 Mar 2011 23:10
  • By Rick_D
  • joined 14 Feb'05 - 3 messages
  • Michigan, United States
