Error Code 148
I have a 2005 Crown FC4020-50 here that is throwing fault code 148. any idea what that is? Tilt, lift, and sideshift work sometimes, but not always
  • Posted 13 Dec 2014 08:59
  • By LukeM
  • joined 13 Dec'14 - 1 message
I had a fault similar but with no event code appeared. The truck had a rotating clamp fitted and if you rotated the clamp for more than a quarter turn, it would drop tilt function for 20seconds. I replaced PCA on the valve block and that cured the issue
  • Posted 3 Feb 2015 08:01
  • By eddy_w
  • joined 7 Jun'11 - 11 messages
  • northamptonshire, United Kingdom
pull pump contactors (P1 and P2) and check for broken armature pin.
  • Posted 2 Feb 2015 01:48
  • By tonymfg
  • joined 16 Jan'09 - 43 messages
  • New Jersey, United States
i am not sure about the fc series but on the sc 4500 sometime the tilt interlock module will cause lift,tilt,and sideshift to sometimes work and sometimes not work.....
  • Posted 14 Dec 2014 02:48
  • By davy
  • joined 7 Dec'13 - 5 messages
UN Forklift FB20-35FZNLZD
SMV (Konecranes) 12-1200B
