Drive system
Esc030ABN24SE083 ser#N452247. This unit runs with a super pc8 drive system. It will not creep in reverse. It will go full speed in reverse after holding the throttle wide open for about 4 seconds. Forward works normally. The battery is fully charged.
  • Posted 15 Feb 2025 09:53
  • By Spielman
  • joined 15 Feb'25 - 1 message
  • Oregon, United States
Kendall Spielman
Spielman,
Make sure the control handle switches are adjusted correctly for reverse travel. Check are connections at the reverse contactor are clean and tight. Make sure all cables are tight. Check drive motor brushes. Good Luck.
  • Posted 18 Feb 2025 00:48
  • By Fishmech
  • Virginia, United States
