Codes I need help with
Customer dropped the unit off a lift gate. Structural damage is fixed. Wires damaged replaced. Unit randomly codes CTRLCARD and FLT60099. It does this while out on a delivery route. It NEVER does it while I'm nearby. Any ideas from the gurus here?
  • Posted 4 Jan 2024 09:14
  • By Mark_Yeman
  • joined 4 May'21 - 2 messages
Mark,
Code 60099 states an internal problem with the control card in the handle. I would suspect there is a failed electrical connection on the card from the shock of being dropped or a crack across the card. Swap with a known good card to test. Good Luck.
  • Posted 30 Jan 2024 06:32
  • By Fishmech
  • Virginia, United States
