CAT EP16KT CODE 33
i have a Cat Ep16KT serial ETB4B01108
this unit is very eratic. when you turn the key on the unit sometimes will not energize the line contactor. and will code 33
sometimes it will energize the lift pump motor several times before it codes out.
any ideas would be appreciated
thanks
  • Posted 20 Jul 2011 00:39
  • By bruce_c
  • joined 28 Jul'10 - 52 messages
  • Missouri, United States
Before you order one up just check there is no earth faults to the pump motor circuit.
  • Posted 21 Jul 2011 02:14
  • By elektrodrive
enquiries@elektrodrive.co.uk
ok i will get one priced.
thanks for your help
  • Posted 20 Jul 2011 06:39
  • By bruce_c
The the most likely fault is going to be in your driver card.
The good news is from what I have been told its not that expensive. Dont know how true that is though :)
  • Posted 20 Jul 2011 06:36
  • By elektrodrive
thanks for the info.
we have swapped out the pump transistor and also swapped the current sensor but the problem remains code 33.
sometimes when i turn the key on the hydraulic pump motor will pulse several times before it codes out. sometimes it will run fine for a minute or two then it will code out again.
is there a flow chart for testing the logic board?
thanks
  • Posted 20 Jul 2011 06:12
  • By bruce_c
Hi Bruce
The fault kind of makes sense with what you have described as it states its a Pump motor faulty transistor drive.
If its not a faulty IGBT then as its erratic it may be a loose wire or a bad connection to that part of the circuit. Best thing to do is strip it and see if the connections on the IGBT are loose and also check the pump circuit current sensor plug and wiring.
The info states either IGBT, or current sensor or the driver board.
  • Posted 20 Jul 2011 00:55
  • Modified 20 Jul 2011 00:57 by poster
  • By elektrodrive
