7FBEU15 code AD1, AD3, AD5 line contactor cycling, no functions
Hi, any ideas on this one? It's for another technician. Contactor cycles, then throws these codes. Thanks
  • Posted 12 Aug 2010 00:19
  • Discussion started by steponmebbbboom
what you're speaking about is an Electrically Enclosed contactor.
they are made for areas that have fine dust that is highly combustible.
  • Posted 13 Jul 2022 15:34
  • Reply by LaGrange
  • Missouri, United States
Strong in mind, Strong in Health.
Hi elektrodrive,
would you be able to send me the infomation on this as i have a friend who has this same problem which i am trying to help him with AC-1 AC-3 AC-5
Thanks in advance
  • Posted 13 Jul 2022 14:09
  • Reply by Jt_Ng
  • Victoria, Australia
Hi, I am changing the all wire arnes of 7FBEU15, so a buy a new one, but the conectors cn120, cn121, cn122, cn123, do not match whit the original wiring cn131, cn132, cn133. and also do not shows in the manual diagram. I buy these arnes using model and serial number. theres something else I don't know
  • Posted 6 Mar 2015 02:52
  • Reply by luis_d
  • TAMAULIPAS, Mexico
Thanks guys, I went out and looked at the machine today. It is a 7FBE with the optional fingertip controls. Problem one was the positive thimble on the battery was rotted away causing the voltage to drop down to 18V when the seat switch was depressed. Secondly, the line contactor tips were badly worn, and on one side more than the other. Third, the entire machine was covered in electrically conductive fine grinding swarf. This is a company that welds together and grinds UL fire door frames. I cut the cable back, installed new thimble, replaced contactor tips, blew off truck with compressed air, then powered up as normal.
Question, Is there a sealed contactor (like a EE rated sparkproof contactor) to replace the original EO contactor? Id like to keep contamination of the contactor and tips to a minimum in addition to blowing off dust on a regular basis.
Yes, this is a time out on the can bus between the CPU and all three AC drivers. I'd think a problem with the connection, the termination resistor or bad CPU. The strange thing is, if there is a complete can bus failure I'd expect to see AD2,4,6 which indicates can bus failure at power up.
  • Posted 12 Aug 2010 22:19
  • Reply by J_Newton
Sorry just realised.its been one of them days :)
AD5
Material handling AC driver + main controller
communication abnormality
Output when the CPU board cannot receive data from the material handling AC driver within specified time.
  • Posted 12 Aug 2010 07:59
  • Reply by elektrodrive
Hi there
The status code states:
AD-2 I Traveling AC driver 1 + main controller communication
abnormality
AD-1
abnormality
AD-3
Traveling AC driver 2 + main controller communication
abnormality
Possibly a break between the wiring from one of the controllers.
If its any help I can copy the relevant pages and send you a copy which covers the checks that you need to do? email me if required.
  • Posted 12 Aug 2010 07:29
  • Modified 12 Aug 2010 07:31 by poster
Mitsubishi FD200
Toyota 02-8FD30
