Where dock safety breaks down and how to fix it
Justin Malone -
Safety First
- 1 Oct 2026 ( #1301 )
4 min read
Tips on dock safety
Tips on dock safety
Justin Malone is the corporate field safety manager at docks and door supplier Miner.
The loading dock is one of the most dangerous places in any facility, not because the work is unusually hazardous in isolation, but because it's where everything converges.
A forklift operator, driver from outside the operation, a receiving clerk, and freight that may or may not be properly secured, all meet in the same narrow space, often under production pressure and on a tight schedule.
When dock safety breaks down, it's rarely a single dramatic failure. It's small gaps in process, equipment, and communication that line up at the wrong moment.
After 14 years in safety work, I've come to think of dock incidents as falling into a handful of recurring failure points. Each one is fixable. None of them get fixed by accident.
The handoff itself
The driver pulling into your dock is a visitor. They don't know your traffic patterns, forklift routes, or procedures, and they're under their own pressure to turn the truck around quickly.
Most of the safety responsibility sits with the host facility because the host controls the equipment, protocols, and people moving in and out of that trailer. The breakdown happens when both sides assume the other has it covered.
Strong dock operations make the handoff explicit: clear signals on when it's safe to approach, defined roles for who chocks the wheels, who locks the trailer, and who gives the all-clear to start loading.
Trailer security and trailer creep
This is the failure point I see most often, and it's the one with the worst consequences. A forklift carrying a 12 to 15 ft. (3.7 to 4.6m) roll of carpet, or any heavy load, puts real force on a trailer every time it crosses the dock plate. If the trailer isn't properly secured, it walks.
That's trailer creep, and once a trailer separates from the dock under a lift truck, the outcome can be severe. Worst case, you have a driver pulling away with a forklift still in the back. I've seen it, and it's not something you forget.
The fix is not a tire chock
Chocks have their place as a backup, but anyone who's spent time on a dock has seen one walk off, get chewed up, or sit there providing little more than a false sense of security.
The better solution is a truck restraint system, a hook or similar device that physically anchors the trailer to the dock. The investment is modest compared to the consequences of a trailer separating from a dock under a loaded lift truck. If your dock is still relying on chocks alone, that's the first thing to change.
Pedestrian and lift truck interaction
Forklift traffic and foot traffic share dock space constantly, and the longer employees work in that environment, the more desensitised they become to the risk.
The fix is a combination of physical separation, including defined walkways, barriers, and mirrors at blind corners, and presence-sensing technology where full separation is impossible.
Presence-sensing equipment is a real asset, but only if it's installed correctly. A device set up wrong creates exactly the false confidence you don't want, so bring in someone who installs them for a living.
Weather and seasonal hazards
Dock safety changes with the calendar, and operations don't always adjust fast enough. A rubber chock with a steel core works on dry pavement and slides like a skate on ice.
Drivers entering and exiting the cab on icy surfaces need three points of contact, and surfaces need to be treated. Don't overlook the hazard overhead. Icicles and sheet ice above the dock door can come down with enough force to do serious damage. Looking up before backing in and clearing ice from above dock doors should be part of the protocol.
Communication and signalling
Most dock incidents involve a moment where two people had different assumptions about what was about to happen. The driver thought the dock was clear. The forklift operator thought the trailer was locked.
Tightening up signalling with dock lights, simple verbal protocols, and defined handoff points eliminates a surprising amount of risk for little cost. What it requires is a facility willing to enforce the protocol consistently, including with drivers in a hurry to leave.
None of these fixes are exotic. The failure points haven't changed much, either. What separates operations that run cleanly from those that don't is whether they treat the dock as a system that needs to be maintained, with equipment, training, protocols, and culture reinforced consistently, or as a place where freight just happens to move.
There are no trade secrets in dock safety. The fixes are well known. The question is whether you put them in place before the incident or after.
Also Read:
What fleets get wrong when they switch to electric forklifts
Jeremy Barth
3 minute read
What fleets get wrong when they switch to electric forklifts Your Focus - 27 Aug 2026 (#1296) Jeremy Barth is a specialist at HOJ Innovations, a materials handling and warehouse solutions company which has been around since 1964.
Physical AI doesn't have a technology problem - it has a business model problem
Yael Fainaro
5 minute read
Physical AI doesn't have a technology problem - it has a business model problem Your Focus - 6 Aug 2026 (#1293) Yael Fainaro, former president & CBO with RGo Robotics, has more than 25 years scaling high-tech innovation to market across different industries. At RGo Robotics she worked closely with material handlings technical and commercial leadership on the front lines of Physical AI adoption.
How to spot and fill dangerous gaps in your MHE training
Stuart Taylor
3 minute read
How to spot and fill dangerous gaps in your MHE training Safety First - 23 Jul 2026 (#1291) Stuart Taylor is managing director of Mentor FLT Training Limited, a UK training provider for all types of material handling equipment and workplace transport.
In this week’s Forkliftaction News , we have two stories reminding us of the power of a generous spirit... Continue reading
Combilift Ltd
March 16-18, 2027 - Stuttgart, Germany
October 26-27, 2026 - Fort Shelby, Michigan, United States
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
