When Better Isn’t Enough: Why the Forklift Industry Struggles to Let Go of Lead-Acid
- 5 Feb 2026 ( #1267 )
6 min read
Lead-acid persists not because it’s better, but because it’s familiar. maxwell+spark explores the human reasons why habit and disruption still outweigh logic and performance in forklift battery decisions.
The question is no longer whether lithium-ion works well in material handling. That debate is settled.
Across duty cycles, climates and applications, lithium-ion has proven itself capable, reliable, safe and highly cost-effective. The performance data is there. The case studies are there. The operational advantages are well understood. Yet, in large parts of the US and Europe, lead-acid is still being specified as the default.
Not because it is better. But because it is familiar.
This is the uncomfortable truth the industry rarely confronts: technology adoption is not driven by logic alone. It is shaped by habit, by organisational memory and by a deep, very human resistance to disruption.
Disruption is harder than inefficiency
From the outside, the argument for lithium-ion seems straightforward.
Higher usable capacity.
Consistent power and voltage delivery.
No battery changes.
No watering.
No gassing.
No cooling periods.
Better energy efficiency.
Better machine life
Lower lifetime costs.
The list is long and well documented, but from inside an operation, the calculation looks very different. Disruption is not theoretical, its on-the-ground effects are practical, immediate and personal. It means retraining operators, rewriting procedures (even if simpler), rethinking charging layouts, perhaps reworking shift patterns. It means uncertainty, less-understood risks and unfamiliar failure modes.
Inefficiency, by contrast, is often invisible. It hides in small daily compromises: slower trucks at the end of a shift, queues at the battery room, high energy costs, capex that only appears later, labour allocated to watering and change-outs, floor space given over to infrastructure that does not move product.
These costs accumulate quietly, whereas disruption announces itself loudly and in most organisations, loud risk is avoided more aggressively than quiet loss.
The comfort of “known problems”
In many US distribution centres, lead-acid has been in place for decades. Battery rooms are built. Staff are trained. Maintenance teams know the routines. Procedures are embedded. The system has a shape and everyone knows where they fit inside it.
When lithium-ion is proposed, the response is often not technical, but psychological:
“We know how to manage this.”
“We know where the issues are.”
“We know how to fix it when it goes wrong.”
There is comfort in known problems.
Power fade is annoying, but predictable. Battery swaps are inconvenient, but scheduled. Watering is tedious, but routine. Lithium-ion, even with all its advantages, introduces unknowns: new charging behaviours, new safety considerations, new relationships between operations and energy utilisation.
It asks organisations to learn again, and learning, in a high-pressure operational environment, is fundamentally disruptive.
Why logic alone doesn’t change behaviour
Much of the industry conversation around lithium-ion assumes that once the data is clear, behaviour will follow. But that is not how human systems work. Procurement teams are trained to compare unit price, not lifecycle complexity. Compliance teams are more comfortable working within existing regulatory frameworks than interpreting new ones. Each group is acting rationally — within their own context, but the problem is that those contexts were shaped by lead-acid.
Lead-acid is not just a battery. It is a system of habits. It has trained people how to think about power, about downtime, about space, about responsibility. It has created roles, routines and identities. This means that lithium-ion does not merely replace a component, it is challenging all of that, and that is a much bigger change than most organisations acknowledge.
The European paradox
In much of Europe, electrification is already the norm. Sustainability targets are taken seriously, ESG reporting is embedded, environmental responsibility is part of corporate identity. And yet, lead-acid often remains the default choice.
European operations are typically highly process-driven. Procedures are documented. Risk assessments are formalised. Safety frameworks are tightly regulated. Change triggers re-certification, retraining, re-auditing. In this environment, lead-acid is “safe” not because it is optimal, but because it is already approved.
Lithium-ion, despite its advantages, represents procedural disruption. It is easier to improve within the existing framework than to challenge the framework itself.
So progress happens — but slowly, and often cautiously.
Where adoption moves faster
Contrast this with environments where disruption is not optional.
In high-throughput Chinese fulfilment centres, space is scarce and volume is relentless. Battery rooms are seen as wasted real estate. Change-outs are interruptions. Power fade is unacceptable. The question is not “what are we used to?” but “what keeps the line moving?”
Similarly, in South African operations facing energy instability, maintenance pressure and tight margins, complexity is a liability. Equipment that requires constant attention is resented and systems that simplify life gain traction quickly. In these contexts, lithium-ion is not embraced because it is modern, but because it reduces friction.
The lesson is not that these markets are more progressive. It is that their operating conditions reward efficiency more brutally.
What the industry often underestimates
The forklift industry is technically sophisticated. It understands machinery, performance and reliability. What it often underestimates is the emotional weight of operational change.
Disruption means:
  • admitting that the old system is no longer fit for purpose
  • asking people to give up expertise they worked hard to acquire
  • creating a period of uncertainty in environments that value control
That is not trivial. It is much easier to tolerate small inefficiencies than to reconfigure a system.
So lead-acid (and in some cases diesel and gas) persists not because it is better, but because it is embedded.
Why this matters now
Warehousing is changing.
Throughput is increasing. Labour is under pressure. Energy costs are rising. Site power is becoming constrained. Operations are being asked to do more with less margin for error.
These trends reward predictability, consistency, low total cost and flexibility.
They do not reward:
  • power fade
  • scheduled downtime
  • manual intervention
  • or infrastructure that consumes space without adding value.
In other words, they do not reward the characteristics that have long been tolerated in lead-acid systems. The gap between how warehouses operate and how their power systems behave is widening.
That tension will not resolve itself.
The uncomfortable conclusion
Most organisations do not resist lithium-ion because they doubt its performance.
They resist it because it forces them to change, and change is disruptive. It creates short-term discomfort in pursuit of long-term gain. That is a hard sell in any environment. It is especially hard in operations where stability is prized and risk is tightly managed.
But avoiding disruption does not avoid cost. It simply disguises it.
Looking forward
The industry does not need more lists of lithium-ion benefits. What it needs is a more honest conversation about why, despite all that evidence, behaviour lags behind.
Because until that human reality is acknowledged, adoption will remain slower than it should be — not because the technology is lacking, but because the change is uncomfortable.
And discomfort, as every operations manager knows, is often the hardest thing to schedule.
If your operation is navigating the transition from lead-acid to lithium-ion, maxwell+spark works with fleets to assess operational fit and power-system design across material handling applications. To learn more about our lithium-ion solutions, visit our Forkliftaction product page.
Get in touch with maxwell+spark
maxwell+spark
+27 (0)... Show
Schuttevaerweg 21,
3044BA, Rotterdam,
The Netherlands
maxwell+spark
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Forkliftaction News is excited to launch our Big Picture Interviews. In this thought-provoking series, we ask industry leaders for their insights on current market dynamics. In this week’s interview , Ralph Cox, Toyota Material Handling Europe’s SVP market operations, talks about why lean manufacturing and automation go hand-in-hand. Keep an eye out for the fortnightly interviews... Continue reading
November 10-12, 2026 - Marina Bay Sands, Singapore
September 16-18, 2026 - Guangzhou, China
The largest butterfly in the world is the Queen Alexandra's Birdwing (ornithoptera alexandrae), with a wingspan of up to 31cm (just over 12 inches). It is an endangered species only found in Papua New Guinea.
ORDER PICKING
FLEET MANAGEMENT
SAFETY SOLUTIONS
ORDER PICKING
FLEET MANAGEMENT
SAFETY SOLUTIONS
