Unstable and Sensitive Loads in the Beverage Industry – Multi-Pallet Forks with Load Stabilizers Scroll down for video
- 4 Jun 2026 ( #1284 )
When your products are unstable as loads but still require high and reliable handling performance, things become interesting.
Wherever large numbers of pallets must be moved in a short time, multi-pallet handling devices are now widely used. The modern solution is multi-pallet forks, which allow the simultaneous transport of 1, 2, 3, 4, 6 or even 8 pallets at once.
Multi-pallet fork DPK-LH in operation
In industrialized markets, multi-pallet forks have largely replaced multi-sideshifters in industrial and commercial loading processes.
However, achieving high handling speeds while ensuring product protection often requires more than standard equipment. To optimally support the load, prevent breakage, and improve process safety, the experience and innovative capability of the multi-pallet fork manufacturer play a crucial role.
Multi-pallet fork DPK-LH opened for handling two pallets
In the beverage industry, bottles are inherently unstable as a load. Even though standard multi-pallet forks are equipped with a load backrest on each fork that acts like a protective grid, this is often not sufficient.
Multi-pallet fork DPK-LH closed for handling one pallet
Additional stabilization can be achieved using chains or crossbars to increase the support and protective effect. However, in some demanding industrial applications even these solutions are not enough to prevent product damage while maintaining the required loading speed.
For such challenging environments, the combination of load stabilizers and double-pallet forks can provide an excellent solution.
Multi-pallet fork DPK-LH handling loads of different heights
For a major beer and soft drink producer, Durwen has developed special load stabilizers for multi-pallet forks. The profiles are closed on the load side to prevent contamination, and the guide systems require very little maintenance.
Multi-pallet forks DPK-ILF with crossbars to extend the load backrest
By using one load stabilizer per fork pair and the F-shaped pressure plates, it is possible to handle one or two pallets safely and efficiently, even when pallet heights differ.
As a result, both loading speed and operational safety were significantly improved.
See the demonstration video:
A glance at the Durwen multi-fork-positioner range. They are ideal for high throughput operations and provide a maximum flexibility in your logistics:
Multi-pallet forks
Multi-pallet forks
For more information, please contact us!
Get in touch with Durwen Maschinenbau GmbH
+49 263... Show
August-Horch-Straße 5
D-56637 Plaidt
Germany
In this week’s Forkliftaction News, we look at the mixed bag of financial results released in the last week. This includes Hyster-Yale which improved quarter-on-quarter, but dropped modestly y-o-y, leading it to forecast a moderate operating loss for 2026... Continue reading
