Product News
- 28 Jul 2011 ( #524 )
New Holland expands the LM5000 telehandler range.
New Holland extends range
Burr Ridge, IL, United States
New Holland has extended the LM5000 telehandler range to include two new compact models, the LM5020 and LM5030.
The LM5020 is suitable for small livestock and horticultural operations, while the LM5030 is ideal for farmers working in hilly conditions, for silage applications or even light industrial applications.
All key stressed components including the machines' chassis and boom are made with thick, reinforced steel for stability when lifting heavy loads at full extensions.
Hoppecke: UK demand growing
Newcastle-Under-Lyme, United Kingdom
Demand for rapid battery-charging systems is growing in the UK, says established battery specialist Hoppecke Industrial Batteries.
Hoppecke has been supplying rapid charging solutions to a major UK automotive manufacturer for over eight years.
But, according to Hoppecke, demand in the UK is only now mushrooming, as the country follows US trends where the equipment is being increasingly adopted by forklift operating companies.
CoGri distributes floor saver
Huddersfield, United Kingdom
CoGri Group has been appointed the exclusive European distributor for the patented SD7 Joint Saver, which will be marketed as the CoGri Joint Stabiliser.
The joint stabiliser is a split aluminium cylinder containing a screw and wedge torque mechanism. It is inserted in floor slabs to repair damage on floor surfaces. Its spring-like mechanism allows it to expand and contract with the slab as it undergoes normal slab movement due to temperature changes.
Forklifts can travel over the repaired joints within five minutes of the work being completed.
UKMHA announces Archies shortlist News Story - 25 Jul 2024 - Newbury, Berkshire, United Kingdom - 1 min read
Movers & Shakers News Story - 21 May 2020 - 1 min read
Hoppecke doubles UK revenue News Story - 25 Apr 2019 - Newcastle-under-Lyme,, United Kingdom - 1 min read
New Holland releasing new telehandler in North America News Story - 13 Feb 2025 - Pennsylvania, United States - 1 min read
New Holland launches new telehandler News Story - 14 Nov 2024 - Modena, Italy - 1 min read
New Holland targets farmers News Story - 24 Feb 2022 - New Holland, PA, United States - 1 min read
