When warehouse space becomes limited, looking upwards can reveal opportunities. Adding another storage level may increase capacity within the existing building. However, if the forklift cannot reach the new pallet positions, warehouse managers face a practical question: replace the truck, install a different mast, or find another solution?
The KOOI® Mast Height Extension from Meijer Handling Solutions offers an alternative. This attachment provides additional lift height, allowing businesses to adapt an existing forklift to changing storage requirements.
Extra reach with a compact design
The Mast Height Extension is an add-on mast with a fork carriage that moves vertically using hydraulic cylinders. These cylinders are integrated into the guide profiles, keeping the construction compact and limiting its overall thickness. The forklift’s existing standard forks can be transferred to the attachment, helping to reduce additional expenditure.
For warehouse managers, the main advantage is the opportunity to access higher pallet positions without immediately investing in a replacement forklift or mast. This is particularly relevant when storage requirements increase but the available floor space remains unchanged.
Higher storage, access through low doorways
A taller conventional mast can create difficulties when a forklift needs to pass through low doorways or move between buildings with restricted clearance. An add-on mast can offer a practical solution where additional lift height is required at the racking, while access along the truck’s operating routes remains essential.
Clear visibility for the driver
For forklift operators, visibility and accurate fork positioning are central to everyday work. The open construction of the KOOI® Mast Height Extension is designed to keep the effect on visibility to a minimum.
Optional equipment can provide further assistance. A camera system gives the driver a clearer view of pallet openings, while a laser helps guide fork positioning. Both options can support precise pallet handling and help reduce damage.
Selecting the right configuration starts with the application: the additional height required, the loads being handled and the clearance available throughout the warehouse. The result is a targeted approach to making better use of warehouse height with existing equipment.
For more information visit: www.meijer-handling-solutions.com or contact us!
