Keeping Cold Chain Moving: ROYPOW Lithium Batteries Power Reliable Forklift Operations in Cold Environments Scroll down for video
- 18 Jun 2026 ( #1286 )
Cold storage and freezer applications are among the most demanding environments for material handling equipment. With temperatures often dropping to -20°C or even as low as -40°C, maintaining consistent forklift performance becomes a daily challenge. In such conditions, battery systems are put under significant stress, directly affecting operational efficiency, safety, and overall costs.
For many cold chain operators, traditional lead-acid battery solutions struggle to keep up. Reduced capacity at low temperatures leads to shorter runtime, requiring more frequent battery changes or charging cycles. Charging itself becomes less efficient, while condensation and frost can increase maintenance requirements and potential safety risks. As warehouse throughput continues to rise, these limitations can quickly translate into downtime and lost productivity.
ROYPOW Lithium Battery Solutions Engineered for the Cold
To address these challenges, lithium battery solutions designed specifically for low-temperature environments are gaining momentum. ROYPOW has developed dedicated anti-freeze lithium battery systems tailored for cold storage forklift applications, engineered to maintain stable performance even in extreme subzero conditions.
Designed for cold storage environments, the system operates reliably at temperatures down to -40°C. Built-in heating supports both charging and discharging, ensuring consistent performance in extreme cold, while integrated insulation helps retain heat and maintain optimal internal conditions. Built-in desiccants reduce internal condensation, and an IP67-rated enclosure protects critical components and connector ports from moisture and corrosion, ensuring stable operation in high-humidity, subzero environments.
ROYPOW has conducted controlled testing at temperatures as low as -30°C to assess performance in low-temperature environments. The results showed stable output comparable to room-temperature conditions, supporting reliable operation in cold storage settings, and no internal condensation was observed, highlighting the effectiveness of the system’s insulation and moisture protection design in preventing performance loss in cold storage environments.
Reliable Forklift Batteries for Cold Storage: ROYPOW Solutions
Real-World Applications: Proven Performance in Cold Storage
Building on these test results, the system has also demonstrated strong performance in real-world cold storage operations. At a large-scale cold storage logistics center in Italy, operating 15 electric pallet trucks, forklifts equipped with ROYPOW lithium batteries were deployed to replace conventional lead-acid systems. In temperatures below 5°C, the fleet previously faced frequent battery swaps and noticeable performance drops, particularly during peak operating hours.
After switching to ROYPOW lithium batteries, the operator reduced daily battery swaps from 3 times to zero and extended runtime per charge from 4.5 hours to over 7 hours. Weekly watering and equalization charges were also eliminated, delivering an 18-month ROI and an increase in pallets moved per shift.
In Australia, the same solution has been deployed on Komatsu FB20 freezer-spec forklifts, which are purpose-built for cold storage operations. Paired with ROYPOW lithium batteries, these trucks deliver stable and reliable performance in subzero environments, supporting continuous operation with reduced downtime and minimal maintenance requirements.
Supporting the Future of Cold Chain Logistics
As global cold storage operations expand, in cold chain logistics, reliable power is no longer just about endurance; it's about ensuring uninterrupted productivity in extreme environments. Lithium battery technology engineered for low-temperature environments offers a clear path toward improved performance and operational continuity.
ROYPOW continues to support the evolution of cold chain material handling with lithium battery solutions designed for reliable performance in real-world cold storage applications.
Get in touch with ROYPOW
ROYPOW
+86 (0)... Show
ROYPOW Industrial Park,
No. 16, Dongsheng South Road, Chenjiang Street,
Zhongkai High-Tech District, Huizhou City,
Guangdong Province, China
ROYPOW
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
September 8-9, 2026 - Barcelona, Spain
November 11-12, 2026 - London, United Kingdom
February 8-10, 2027 - Mumbai, India
