How lithium-ion battery packs are powering the next generation of forklifts
Jaesung Choi -
Your Focus
- 23 Apr 2026 ( #1278 )
Jaesung Choi
Jaesung Choi
Jaesung Choi is a product manager with Bobcat. He has 15 years of experience spanning engineering, strategy, and product management in the material handling industry.
Forklift operators are under increasing pressure to boost productivity, minimise downtime and control rising operating costs, driving many to re-evaluate their power solutions.
Lithium-ion battery packs are gaining traction as a modern alternative to traditional lead-acid systems, offering improved efficiency, reliability and long-term value.
Understanding how these battery types compare, along with key safety considerations and factors to evaluate before making the switch, is critical for operations looking to optimise performance.
Efficiency and reliability of lithium vs. lead-acid batteries
The shift to lithium-ion batteries is driven by technological advantages, optimising workflow through efficiency and reliability.
Conventional lead-acid batteries typically deliver 1,000 to 1,500 cycles, while lithium-ion batteries can reach 2,500 to 3,000 cycles or more, significantly extending service life.
Lithium-ion powered forklifts are increasingly commonplace
Lithium-ion batteries also stay in the truck eliminating the 20–30 minutes of battery swap downtime per shift typically required with lead-acid systems.
These battery packs deliver consistent power output until nearly depleted, ensuring predictable performance through the entire operation.
Temperature performance further enhances the appeal of lithium-ion batteries. Many are equipped with integrated heating systems that activate automatically in cold conditions. This feature allows full operation performance in environments down to -4°F (-20°C), making them well-suited for cold storage or outdoor applications where lead-acid batteries may struggle.
Additional benefits of lithium-ion batteries include:
  • Zero watering or “equalising” versus weekly watering and cleaning
  • Full charge in 1 – 2 hours compared to 8 hours of charging and 8 hours of cooling
  • No dedicated “battery room” leaving warehouse space for staging areas or extra storage
Many of these batteries are engineered to withstand the daily rigours of forklift operations; however, collisions or heavy object drops should be treated as a critical safety event.
These cause visible deformation or enclosure damage that can lead to potential short circuits, which carry a higher risk of thermal runaway.
Any damaged battery pack should be removed from service immediately and inspected by a qualified service technician before further use.
Key considerations before making the switch
Before transitioning to lithium-ion batteries, operators should assess their operations and their facilities.
These batteries need a facility that can support higher electrical loads associated with fast charging. Charging stations should be placed near break rooms or high-traffic areas, rather than in a remote corner.
While lithium-ion batteries carry a higher upfront cost than lead-acid alternatives, there’s a lower cost to ownership with many operators seeing a return on investment within two to three years.
Savings are driven by reduced labor, lower energy consumption and longer lifespans.
Safety considerations when handling lithium-ion batteries
As with any power system, safety remains a critical consideration. Lithium-ion batteries rely on a battery management system (BMS) that serves as the brain of the unit, monitoring voltage, temperature and charge.
Communication between the BMS and forklift is essential to prevent issues such as overcharging or deep discharging, leading to thermal runaway risk.
Powering a more efficient fleet strategy
As material handling operations push for greater uptime and streamlined performance, lithium-ion battery packs are becoming a cornerstone of more efficient, modern fleet strategies.
With the ability to reduce downtime, simplify maintenance and support consistent output, they offer a forward-looking approach to power management.
For operations evaluating performance goals and safety requirements, lithium-ion technology provides a scalable solution built to meet the demands of today’s fast-moving environments.
Also Read:
What fleets get wrong when they switch to electric forklifts
Jeremy Barth
3 minute read
What fleets get wrong when they switch to electric forklifts Your Focus - 27 Aug 2026 (#1296) Jeremy Barth is a specialist at HOJ Innovations, a materials handling and warehouse solutions company which has been around since 1964.
Physical AI doesn't have a technology problem - it has a business model problem
Yael Fainaro
5 minute read
Physical AI doesn't have a technology problem - it has a business model problem Your Focus - 6 Aug 2026 (#1293) Yael Fainaro, former president & CBO with RGo Robotics, has more than 25 years scaling high-tech innovation to market across different industries. At RGo Robotics she worked closely with material handlings technical and commercial leadership on the front lines of Physical AI adoption.
How to spot and fill dangerous gaps in your MHE training
Stuart Taylor
3 minute read
How to spot and fill dangerous gaps in your MHE training Safety First - 23 Jul 2026 (#1291) Stuart Taylor is managing director of Mentor FLT Training Limited, a UK training provider for all types of material handling equipment and workplace transport.
Lithium Storage
Leading China-based developer and manufacturer of Industrial Lithium Batteries.
September 29-01 October, 2026 - Cairo, Egypt
October 6-7, 2026 - London, United Kingdom
Lithium Storage
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
