HAWKER LIFEPLUS® Xtreme Charger: The Ultimate Outdoor Motive Power Battery Charger Scroll down for video
- 2 Jul 2026 ( #1288 )
4 min read
Electric forklift adoption is accelerating amongst agriculture, outdoor warehousing, and ground support equipment. But charging infrastructure hasn’t developed quite as quickly.
Historically chargers have been built for indoor applications with a controlled and protected environment. But industries like agriculture, lumber yards, and airports operate in unpredictable outdoor environments, and outdoor charging demands a different standard.
The good news? That new standard is here.
Key Takeaways:
  • Electric forklifts represent 66% of the North American market[1] and growing, but a majority of forklift battery chargers are engineered for indoor charging.
  • Outdoor charging applications such as Ground Support Equipment (GSE), Agriculture, lumber, and outdoor warehousing industries are facing tightening electrification mandates.
  • The HAWKER LIFEPLUS® Xtreme[2] charger is purpose-built for outdoor environments: IP54 rated, temperature-control, and compatible with all major battery chemistries.
Why Standard Chargers Can’t Support Outdoor Operations
Unpredictable outdoor environments introduce risks that indoor environments simply just don't face:
  • Wind-driven rain
  • Dust and airborne debris
  • Temperature extremes in both directions
A charger that performs flawlessly in an indoor application can fail within months in any of these conditions, and the customer won't always know why until the damage is done.
The Ingress Problem: IP Ratings and Why They Matter
IP stands for Ingress Protection. The rating system uses two numbers: the first indicates protection against solid particles like dust, the second against liquids.
For outdoor motive power applications, the relevant ratings are:
  • IP20: Standard indoor charger. No water protection. Not suitable for outdoor use.
  • IP54: Dust-protected and splash-resistant from any direction. Currently the highest rating available for a dedicated heavy-duty motive power charger.
In this product category, IP54 is state-of-the-art, and right now, the field of manufacturers who have reached even that benchmark for a dedicated outdoor charger is very short.
The Chemistry Problem: Temperature Extremes
Extreme heat and cold are two major factors that can complicate outdoor charging.
Cold temperatures can cause standard chargers to misread battery conditions, terminate charge cycles early, and push current when they shouldn’t.
Heat creates the opposite problem: sustained high temperatures during charging accelerate battery wear and shorten service life in ways that compound quickly in environments like airport tarmacs or Sun Belt summers.
The Infrastructure Problem: The Electrical Grid is Often the Bottleneck
Electrical infrastructure is the part of outdoor electrification conversations that catches operations off guard. Most forklift chargers require 480V, 3-phase service, and outdoor or remote facilities sometimes lack the capacity to support that without upgrades.
Martin Boyd, VP of Product Planning at Hyster, frames it well: his advice to operations considering electrification[3] is to work closely with a dealer to conduct a power study and assess site considerations. That includes whether the electrical grid will support the chargers needed and whether any layout adjustments are needed to make charging locations practical for operators.
HAWKER LIFEPLUS® XTREME OUTDOOR BATTERY CHARGER
The HAWKER LIFEPLUS® Xtreme: What Dealers Need to Know
The HAWKER LIFEPLUS® Xtreme[4] is one of the only purpose-built outdoor chargers available for heavy-duty motive power outdoor applications. Here's what matters for customer operations.
IP54 Protection Engineered Right In
The HAWKER LIFEPLUS® Xtreme Charger's IP54 rating covers dust protection and water spray from any direction, making it appropriate for areas subject to rain exposure such as airport tarmacs, construction sites, and rail yards.
Internal heaters, fans, and a filtration system actively manage the thermal and humidity environment inside the unit. That internal management is what makes it a genuine outdoor solution.
Universal Battery Compatibility with Intelligence
The HAWKER LIFEPLUS® Xtreme Charger is compatible with all HAWKER battery chemistries:
For lithium, full CANbus communication means the battery management system (BMS) controls charge parameters directly; making the charger and battery operate as a coordinated system.
For mixed-chemistry fleets or operations planning a chemistry transition, that's meaningful flexibility in a single outdoor-rated investment.
Modular and Scalable
Built on 3.5kW modules, the HAWKER LIFEPLUS® Xtreme charger configures at 7kW, 14kW, or 21kW, making it right-sized for today, with room to scale for the future.
Smart and Connected
Onboard Ethernet and Bluetooth connectivity with a free mobile app handles remote setup and data download. A 4.3" color display with external IP54-rated pushbuttons for start, stop, and equalize keeps the HAWKER LIFEPLUS® Xtreme charger practical in outdoor conditions.
Up to 94% Efficiency
High-frequency modular technology delivers the same efficiency the HAWKER LIFEPLUS® chargers are known for indoors, without compromise outdoors. The HAWKER LIFEPLUS® legacy continues to deliver maximum performance and energy efficiency to customer’s operations.
The Bottom Line
Electric adoption is rising across the industries that have historically been hardest to electrify. But agriculture, airport ground support equipment, and railyards aren't marginal segments. They represent meaningful fleet volume, strong regulatory tailwinds, and a customer base that has largely been told "not yet" when it comes to outdoor charging for forklift fleets.
Ready to Talk Outdoor Charging Solutions?
The opportunity is there, and it’s yours to own. If you’re evaluating outdoor charging, connect with your HAWKER representative or call 1-877-7HAWKER to learn more about the HAWKER LIFEPLUS® Xtreme Charger.
RESOURCES:
  1. https://www.news.market.us/forklift-statistics/
  2. https://www.hawkerpowersource.com/products/chargers/lifeplus-xtreme/
  3. https://www.supplychain247.com/article/user_priorities_drive_motive_power_choices
  4. https://www.hawkerpowersource.com/news/hawker-lifeplus-xtreme/
Get in touch with Hawker Powersource, Inc.
+1 423-... Show
PO Box 808
Ooltewah, TN 37363
United States
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
September 8-9, 2026 - Barcelona, Spain
November 11-12, 2026 - London, United Kingdom
February 8-10, 2027 - Mumbai, India
