Enhanced visibility for safer multi-pallet handling Scroll down for video
- 7 May 2026 ( #1280 )
MEYER 2/1 Multiple Pallet Handler (series 6-52) with Easy-FORK Vision Systems
Faster cycles, safer handling, seamless integration: Bolzoni Group's new multi pallet handler with integrated cameras.
Multipallet handling is all about speed, but it is also where visibility becomes a real safety and productivity constraint. When carrying two pallets, the load often blocks the operator’s forward view precisely during the most critical moments: aligning fork tips with pallet pockets, placing pallets into racking, or loading trailers. Bolzoni Group addresses this challenge on the MEYER 2/1 Multiple Pallet Handler (series 6-52) by integrating Easy-FORK Vision Systems with a centrally mounted front camera and a fork tip camera that automatically switch on a single in-cab monitor, delivering clear guidance both with and without load.
Increased productivity in multi-pallet applications
Multiple pallet handlers are widely used in industries with intensive handling of palletized goods such as the soft drink industry, breweries, mineral water bottling plants, pallet manufacturing and the brick industry, where cycle time directly impacts logistics costs. MEYER Multi-Pallet Handlers drastically reduce handling times, increasing productivity and lowering logistics costs. The MEYER range offers solutions for handling up to 8 pallets simultaneously, including customized solutions to optimize logistics processes.
MEYER 2/1 multiple pallet handler with easy-FORK dual camera system for faster, safer pallet handling.
Two cameras, optimal visibility with or without a load
The Easy-FORK configuration for the MEYER 2/1 Multiple Pallet Handler combines two camera views displayed on a single in-cab monitor:
  • a front camera, centrally mounted on the attachment, and
  • a fork tip camera, fully integrated into the fork tip.
This setup provides unobstructed visibility both with and without a load on the forks, supporting safer and smoother pallet entry, storage and trailer loading operations.
Front camera (120° viewing angle)
The front camera captures the fork tips and the center of the pallet fork pockets, supporting the driver in limited visibility situations, such as unloading operations with forklifts with elevated cabs, conveyor-belt handling and high lifting heights, while maintaining an ergonomic seating position.
Fork tip camera (52° viewing angle)
The tip camera provides a complete forward view even with loads on the forks, offering optimal visual support for warehouse applications, pallet storage in racking systems and trailer loading.
The tip integrated camera gives the operator a clear frontal view, even during the most delicate operations.
Automatic image switching: one monitor, full focus
A key advantage is the automatic switching mechanism between the two camera views, displayed on one single monitor in the operator’s cab. A sensor positioned at a defined distance from the fork tip switches the displayed image depending on the loading situation: when approaching and picking up the pallet the monitor initially shows the front camera; if the sensor becomes covered while entering the pallet, the image switches to the fork tip camera, and vice versa.
This eliminates the need for a second monitor and avoids split-screen solutions with reduced display size, helping the operator stay fully focused on the manoeuvre.
MEYER 2/1 Pallet Handler with easy-FORKS vision system
Robust technology designed for demanding environments
The Easy-FORK Vision Systems components are engineered for clear visibility and reliable performance even in demanding conditions. The system features robust, high-quality cameras with IP69K protection and solutions designed for cold storage applications thanks to an integrated defogging system.
  • The front color camera includes 6 IR LEDs to ensure visibility even in dimly lit environments.
  • The fork tip camera is a robust IR camera with three LEDs, fully integrated into the fork tip, with the connection cable running protected inside the fork tine.
  • Images are displayed on a high-resolution 7’’ TFT LCD monitor (16:9), with metallic RAM support and 5 language display selection, designed to operate from -30°C to +70°C. The system is powered by the forklift battery and is available with wireless or wired connection between camera and monitor.
A complete range for every need
The Easy-FORK vision system range includes several solutions tailored to different applications:
This modularity makes the system adaptable to any forklift truck and operational context.
For more information on our products visit our website https://en.bolzonigroup.com/, get in touch with Bolzoni Group, or contact the nearest BOLZONI, AURAMO and MEYER representative.
Bolzoni, Auramo and Meyer are Bolzoni Group brands.
The Bolzoni Group is a market leader in the production of forklift truck attachments, forks and lift tables. The company has manufacturing plants in Italy, Germany, Finland, America and China and through its network of direct branches and independent dealers covering all continents it is able to satisfy all market requirements.
Bolzoni SpA (Group HQ)
+39 052... Show
Via I Maggio, 103
I-29027 Casoni di Podenzano,
PC, Italy
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
In this week’s Forkliftaction News , we report on a number of product launches including an Auto-Navigation Forklift Robot from Chinese equipment maker Leapting, developed for utility-scale solar construction sites... Continue reading
ORDER PICKING
FLEET MANAGEMENT
SAFETY SOLUTIONS
October 28, 2026 - Melbourne, Victoria, Australia
November 3-6, 2026 - Shanghai, China
ORDER PICKING
FLEET MANAGEMENT
SAFETY SOLUTIONS
