Bolzoni SILVER LINE: the right balance between investment, availability and reliability
- 6 Aug 2026 ( #1293 )
4 min read
The Bolzoni SILVER LINE range offers the right balance between reliability, availability and investment for everyday material handling applications.
In today's material handling industry, companies are challenged to maintain productivity while making careful investment decisions. Across industries such as recycling, paper, logistics, manufacturing and distribution, there is growing demand for attachments that combine reliability, performance and value.
This is exactly the philosophy behind the Bolzoni SILVER LINE range: a portfolio of robust and readily available forklift truck attachments designed for the most common handling applications. Built on proven engineering and high-quality components, SILVER LINE provides an effective solution for customers seeking dependable performance with short delivery times and excellent value.
Part of Bolzoni Group product portfolio, the SILVER LINE benefits from decades of expertise in the design and manufacture of forklift truck attachments, helping customers worldwide improve efficiency, productivity and safety.
Reliable solutions for demanding handling applications
Since its introduction, the SILVER LINE range has supported customers across multiple industries with dedicated handling solutions. The portfolio includes fork clamps, bale clamps, carton clamps, multipurpose clamps, rotating paper roll clamps and rotating fork clamps, designed to meet a wide range of application requirements.
Thanks to a make-to-stock production strategy and centralized European inventories, many models are available with reduced lead times, helping customers quickly respond to fleet expansions, replacement needs and changing operational demands.
Combined with proven components and maintenance-friendly design, Bolzoni SILVER LINE attachments deliver reliable performance and long-term efficiency across a wide range of applications.
Bolzoni SILVER LINE Fork Clamps: versatility and long-term value
Among the most versatile models in the range, the Bolzoni SILVER LINE Fork Clamps are designed to handle both palletized and unpalletized loads with a single attachment. Commonly used for textiles, fibers, boxes, concrete products and other industrial goods, they combine clamping and fork handling functions in one solution.
Featuring high-tensile aluminium profiles with wear-resistant plastic inserts, they help reduce wear and maintenance requirements, while the optimized frame design ensures excellent visibility and high residual capacity. The result is a reliable and flexible attachment capable of supporting a wide variety of applications.
Bolzoni SILVER LINE Clamps: built for heavy-duty environments
The SILVER LINE Bale Clamp is designed for demanding handling environments, offering robust construction and dependable performance in intensive operating conditions.
In paper industry applications, as well as in the handling of cotton, wool, tobacco, fabrics and other baled materials, attachments are often exposed to intensive working conditions, impacts and continuous operating cycles.
Thanks to their robust frame structure, the Bolzoni SILVER LINE Bale Clamp is designed for heavy-duty applications, while the slim arm profile facilitates easy entry between closely stacked bales and maximizes loading and unloading efficiency. Protected hydraulic components and reliable cylinder mounting solutions further contribute to dependable performance and reduced downtime.
For operations requiring greater versatility, the Bolzoni SILVER LINE Multipurpose Clamp offers an effective solution for handling a wide variety of unpalletized loads, including boxes, textiles, fibers, concrete blocks and drums. Its secure load grip, ensured by replaceable rubber strips, allows safe handling even at reduced clamping pressures.
SILVER LINE Carton Clamps: safe and damage-free appliance handling
Secure grip, reduced product damage, and longer service life: the Bolzoni SILVER LINE Carton Clamp is engineered for efficient appliance handling in distribution and logistics operations.
The Bolzoni SILVER LINE Carton Clamps are designed for the handling of household appliances and white goods, where secure gripping and damage-free handling are essential. Large surface aluminium pads, combined with a high-friction vulcanized rubber lining, ensure a positive grip while minimizing product damage.
The interchangeable left-right and up-down pads promote more even wear, helping to extend service life and reduce maintenance costs, making the attachment a reliable solution for distribution and logistics operations.
Bolzoni SILVER LINE Rotating Paper Roll Clamps: reliability for paper handling
Designed for paper industry applications, the SILVER LINE Paper Roll Clamp combines reliable load control with efficient roll positioning.
The Bolzoni SILVER LINE360-degree rotating paper roll clamps are designed for the handling of single paper rolls in both vertical and horizontal positions. Featuring 360-degree continuous rotation, pivoting arm movement and a slim arm design with curved profiles, they allow operators to handle rolls efficiently while maintaining secure load control.
Combined with robust hydraulic components and a design developed for intensive operation, these attachments offer paper producers, converters and logistics operators a dependable solution that supports productivity while protecting the handled product.
Added confidence with a 36-month warranty
Confidence in product quality is reflected in the warranty coverage available across the entire SILVER LINE range. All Bolzoni SILVER LINE attachments are supported by a 36-month warranty program or 6,000 operating hours, whichever comes first, providing customers with additional peace of mind and reinforcing the range's reputation for reliability and long-term performance.
A trusted solution for fleets and rental operations
The combination of dependable performance, optimized investment and rapid availability makes SILVER LINE particularly well suited for fleet operators and rental businesses.
Whether supporting temporary handling requirements, fleet expansion projects or everyday operations, the range provides a practical and reliable solution capable of meeting the expectations of a wide variety of industries.
For more information on the Bolzoni Silver Line product range, get in touch with the Bolzoni Group Silver Line Specialist, send an email and ask for our references on the range, or to organize a demo unit at your facilities.
Visit the dedicated SILVER LINE section on our web site and contact us, or contact the nearest BOLZONI, AURAMO and MEYER representative.
Bolzoni, Auramo and Meyer are Bolzoni Group brands.
The Bolzoni Group is a market leader in the production of forklift truck attachments, forks and lift tables. The company has manufacturing plants in Italy, Germany, Finland, America and China and through its network of direct branches and independent dealers covering all continents it is able to satisfy all market requirements.
Bolzoni SpA (Group HQ)
+39 052... Show
Via I Maggio, 103
I-29027 Casoni di Podenzano,
PC, Italy
In this week’s Forkliftaction News, we look at the mixed bag of financial results released in the last week. This includes Hyster-Yale which improved quarter-on-quarter, but dropped modestly y-o-y, leading it to forecast a moderate operating loss for 2026... Continue reading
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
