A Smarter Approach to Leaf Chain Supply in Forklift Manufacturing Scroll down for video
- 12 Mar 2026 ( #1272 )
In forklift design and manufacture, few components carry greater responsibility than the mast lifting system. Leaf chain sits at the heart of that system, quietly doing the heavy work day after day. As production demands increase and manufacturing models become leaner, how leaf chain is specified, assembled and supplied is becoming a strategic consideration for OEMs.
For many manufacturers, the traditional approach - i.e. buying bulk chain and assembling in-house - is no longer the most efficient or reliable option.
The Role of Leaf Chain in Forklift Performance
Leaf chain is designed specifically for lifting applications. Its high tensile strength, resistance to elongation and compact design make it ideally suited to forklift masts, where consistent, controlled movement is essential for safety and load stability.
Precision matters. Incorrect chain length, inconsistent assembly or sub-standard fixings can lead to uneven lifting, accelerated wear and avoidable downtime. In a production environment, these risks are amplified.
"Our customers tell us that having ready-to-install leaf chain assemblies removes one of the biggest variables on the production line," says Dan Hargraves, Head of Sales at FB Leaf Chain. "It saves time, reduces errors, and ultimately helps them deliver more reliable machines to their own customers."
FB Leaf Chain Lab l Tensile Testing Machine
Why Pre-Assembled Leaf Chain is Built for Production Lines
Leaf chain assemblies provide a practical solution to these challenges. Supplied cut to length and assembled to exact specifications, they arrive ready for immediate installation.
A typical assembly includes the correctly specified leaf chain, anchor bolts and end fixings matched precisely to the mast design. The result is a component that integrates seamlessly into the build process, removing variability and reducing reliance on manual preparation.
Benefits for manufacturers:
  • Reduced labour and handling on the factory floor
  • Elimination of cutting errors and material waste
  • Greater consistency across production runs
Chain Kits That Simplify Manufacturing
Beyond individual assemblies, complete chain kits offer further efficiencies. By supplying all required chain-related components together, our kits ensure that every build has exactly what is needed – no more, no less.
"We work closely with OEMs to make sure every kit is configured exactly for their assembly process," adds Dan Hargraves. "One package, everything in the right place, ready to go. It takes stress off their production teams and keeps their lines moving."
For forklift manufacturers operating lean or just-in-time production models, this approach reduces stockholding, simplifies logistics and helps maintain line flow. Kits can be configured for mast systems, boom applications or more complex lifting arrangements, depending on the equipment being produced.
Bespoke Kits for OEM-Specific Designs
Forklift designs vary widely, and standardised solutions are not always appropriate. Bespoke leaf chain kits allow OEMs to define exactly how components are supplied, packaged and sequenced to support their own manufacturing processes.
This can include:
  • Custom chain lengths and tolerances
  • Pre-configured assemblies for specific mast geometries
  • Packaging designed to align with build stations and assembly order
We allow manufacturers to gain greater control over quality while reducing internal complexity.
Quality, Traceability and Assurance
Reliability is non-negotiable. Professionally manufactured chain assemblies and kits provide full traceability, documented quality control and consistent specifications across every unit supplied.
This level of assurance not only supports product safety but also simplifies compliance, auditing and long-term maintenance planning.
A Strategic Shift in Component Supply
As forklift manufacturers continue to balance cost control with performance and safety, many are reassessing where specialist suppliers can add value. Outsourcing leaf chain assemblies and kits to an experienced partner allows OEMs to streamline operations while maintaining confidence in one of the most critical elements of the machine.
"We’ve seen a real shift in how manufacturers think about chain supply," concludes Dan Hargraves. "It’s no longer just about buying a component, it’s about integrating a solution that saves time, improves quality, and supports the production line every day."
If you’re evaluating how leaf chain assemblies or bespoke kits could simplify your production process, reduce variability and support lean manufacturing, FB Leaf Chain works closely with forklift OEMs to develop solutions tailored to their exact requirements.
To discuss your application or explore a more efficient approach, contact us here.
Get in touch with FB Leaf Chain
FB Leaf Chain
+44 014... Show
FB Chain
Works Rd
Letchworth Garden City
SG6 1LP
FB Leaf Chain
It has been a big week of product launches for the materials handling sector... Continue reading
October 12-15, 2026 - Detroit, MI, United States
