Yale NR045EB (2019) – Dead in "ON" Position, Only Runs When Key is Held in "Momentary" Position
Yale standup reach forklift NR045EB (2019) - Dead in "IGN" Position, Only Runs When Key Held in "ST" Position
Description
Model: 2019 Yale NR045EB Reach Truck
Serial/Model #: NR045EBNM36TE157
The Issue: My forklift will not power up when the key is turned to the standard "ON" (Position 1). The display stays dark and the contactors do not click. However, if I turn the key further into the Momentary/Spring position and keep physical pressure on it, the display lights up and the lift functions. As soon as I let go and the key springs back to Position 1, the lift shuts off completely.
Switch Wiring Details:
The switch is a 3-position, 3-wire setup:
Position 0 (OFF): Labeled as BATTERY.
Position 1 (ON): Labeled as IGN.
Spring Position: Labeled as ST and connected to its own separate wire.
What I have already done:
Replaced the Ignition Switch: Installed a brand-new switch, but the problem is identical.
Thank you in advance for any technical insights or wiring diagrams you can share to help me resolve this.
Also, if anyone has a service manual or wiring schematic for this NR045EB model and is willing to share, it would be a huge help for tracing this circuit.
  • Posted 28 Apr 2026 02:59
  • By right_w
  • joined 20 Jul'18 - 3 messages
  • United States
Toyota 8FD30
Singapore
USD18,000
UN Forklift FB25N1LZ1
September 29-01 October, 2026 - Cairo, Egypt
October 6-7, 2026 - London, United Kingdom
Cortney Hunt Cortney Hunt
COO, Intelligrated, Trew and Transnorm
Automation manager, N.C. Nielsen
Toyota 8FD30
Singapore
USD18,000
Neptune was discovered in 1846. It then took 165 years, or until 2011, for the planet to complete one orbit of the sun.
