Yale GLC030 Mazda help needed
I am working on a Yale GLC030ADJUAF083 truck sn: 463732
I paid a local guy to fix an oil leak, he brought me back a nightmare. I am already a brand new cylinder head and gasket kit into his "repair". It is timed correctly, and the head and rockers are properly setup (flatspot down). I am timing it according to 1342 CW rotation of the distributor. When I took the system apart to do the repairs, the Impco regulator "water out" side is plumbed to the bottom of the intake manifold. Is this correct, the forklift did run? I included the pictures I took of the system prior to disassembly, the line I am talking about is centered right in the pictures with some yellow overspray on it.
I don't have a correct manual for this lift, I have one ordered for an AF lift. Does anyone have a schematic for the LPG line connections for the lift? I need to get this thing up and going as soon as possible.
Second Question. The plastic 2.0 covers have the standard BTDC marking on them for timing, however, there is no way to get to them or read them with a timing light. There is a seel pointer that sticks out from the front of the motor and with the timing at TDC the pulley indicators align with the pointer. Am I to use this for timing, I am assuming that I am supposed to, I just want to be sure.
  • Posted 22 Jun 2026 13:04
  • By tom206_t
  • joined 6 Jun'16 - 10 messages
Tom206
Your first question the hoses are correct one to the bottom of the manifold and the other comes off a pipe to the converter.. Second question to time that engine you use the metal pointer sticking out not the markes on the cover there is a white cut on the bottom of the crank pulley you remove the hose from the vacuum advance and block the hose use your timing light and time the engine to the white mark on the pulley tighten down the disturbutier and put back the vacuum hose to the dist. Hope this helps.
  • Posted 28 Jun 2026 05:00
  • By Scott_
  • joined 16 May'21 - 342 messages
Scott
edition #1289 - 9 July 2026
In this week’s Forkliftaction News , we continue our coverage of CeMAT Australia with a report on how the lack of local after-sales support and service is hurting new foreign entrants into the Australian market... Continue reading
Terberg RT223
Ncn 110TH
Ncn 110TH 2015
