Unicarriers AS1N1L15Q no functions, no error codes on dash
Hi, I have a 2016 unicarriers AS1NL15Q serial number AS1N1E721039
it has no functions. The dash turn on and shows no error codes. The line contactor doesn't pull in (a new one has been fitted) the wiring loom has been checked. Truck has previously had rodent damage but this was repaired 2 years ago.
Can anyone please offer and advice as its got us all scratching our heads
  • Posted 9 Jan 2026 19:21
  • By Austen_Reed
  • joined 9 Jan'26 - 2 messages
  • United Kingdom
Hi,
Thanks for your reply, yes the seat and seatbelt sensors both work as they should.
  • Posted 27 Jan 2026 23:49
  • By Austen_Reed
  • United Kingdom
Did you check the seat belt/pressure wires, switch? The lift won't operate if the seat pressure switch isn't activated. Also did you check the fuses?
  • Posted 17 Jan 2026 04:04
  • By Alan_Nagle
  • joined 16 Jan'26 - 1 message
  • PA, United States
Big Al
Terberg RT223
Ncn 85TH
Ncn 85TH 2014
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
Linde Material Handling
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
