traction motor overheat, excess current
I'm having a new challenge with an old Daewoo B30S-2 electric lift truck that I maintain for a vegetable farm. Current demand for traction has gone up dramatically and traction motor is heating up too easily and severely. I've checked the items below and would love ideas of what to examine next:
- acceptable voltage sag under load, Vbatt doesn't drop below 45V even when traction current limit is reached
- pronounced smell of hot insulation after just a couple minutes operation and traction motor thermistor (on field windings apparently) throws fault also after just a few minutes operation
- heat discoloration visible on armature windings where they join the commutator.
- no mechanical drag from differential or front brakes (drum). Tested with wheels up.
- motor spins freely forward & reverse by turning fan on armature or via wheels/diff when lifted.
- motor is free of debris and pretty clean. Dust was blown out but there wasn't much. No airflow issues
- motor commutator looks excellent, no pitting or brush damage, smooth and uniform carbon film on comm. Was turned and polished and run-in properly when motor was rebuilt <100hrs ago
- brushes, brush leads & brush holder all look perfect. all new at time of rebuild
About this truck:
- This is a Battery-electric 48V 4-wheel counterbalance truck with 1 traction motor and 1 pump motor, both series-wound.
- Traction setup is single ˜13" diam. series-wound motor mated directly to open diff.
- Traction motor is in good shape and was rebuilt with new brushes and brush holder, new brgs, when I got it. turned the comm too as it had been damaged by pitting/arcing.
- Motor control is transistorized, early 1990s I believe, with power chopped by 4 massive transistors in concert with several huge diodes. I'm pretty familiar with the power electronics/electrics, have done a fair bit of troubleshooting on it in the past and I have the service manual. No visible damage or heat discoloration on power electronics.
I'm going to check stored error codes and get some photos now.
Any leads or ideas of where to look next are welcome. Thanks in advance
  • Posted 9 Oct 2026 23:05
  • By Reid_in_QC
  • joined 9 Oct'26 - 1 message
