TOYOTA 7FGF15/2001 SAS error 65
Hello everyone,
Hope someone who specialize in Toyota forklift may help solve this mystery...
Got Toyota 7FGF15 from 2001 with error 65 throwing on hour meter display and SAS lamp blinking.
From manual description it seems there is problem with tilt solenoid No.2 however this truck.... doesn't have one !!!
This particular truck only does have tilt solenoid No.1 fitted and SAS controller internal electronic parts aren't there for solenoid No.2 output.
So why this **** is throwing an error for it?
Is there a configuration error where you can set how many tilt solenoids are fitted in the valve block?
Valve block is with manual levers btw, but there is one solenoid behind tilt spool which is tilt solenoid No.1
Any help??
  • Posted 20 Feb 2026 21:40
  • By zygmunt_s
  • joined 22 Oct'08 - 47 messages
  • Zachodniopomorskie, Poland
hy,
There should be a sensor fitted above the righthand tiltcylinder.
Is there a knop on the top of the lever that you can push and hold to set the forks straight?
John
  • Posted 27 Feb 2026 05:41
  • By John50
  • joined 7 Sep'19 - 155 messages
  • Netherlands
REPOWERTEK Inc
Stu Jacover Stu Jacover
Chief executive officer, TVH
