Toyota 42-7FGF15 - rear work lamp not working
Hi,
I bought a rear work light for my truck. I already had a wiring connector at the back. I just bought the original lamp, connected it, and unfortunately, it doesn't work. It doesn't work when I turn on the headlights, and I also checked with reverse gear engaged. I started the engine. Nothing happens. The lamp doesn't light up. I checked with a multimeter, and there's no voltage at the connector. Should this lamp have an additional switch? I have all the relays and fuses in the fuse box; nothing is missing. Please help. What else can I check? I've marked the lamp I'm having trouble with in the photo.
  • Posted 28 Feb 2026 01:41
  • By Lukas_Adams
  • joined 1 Jun'22 - 15 messages
  • Poland
I checked it first and everything seems to be complete :(.
  • Posted 28 Feb 2026 05:03
  • By Lukas_Adams
  • Poland
Is there any empty fuse spaces ? If unit came without light but with connection there will not be a fuse and or relay for it in the box
Check that hope it helps
  • Posted 28 Feb 2026 04:35
  • By John_Bradley
  • joined 10 Aug'22 - 313 messages
Jb69
