Lower not working
It seems when we raise up and then step off the deadman's switch and then step back onto the switch and try to lower it won't, one green light blinks, if then we step back on the switch raise it up a little and then it will go down. Wondering if anyone has had this issue and if it might be the switch, if we keep pressing the switch it seems to work? any input will be great
  • Posted 29 Feb 2024 01:56
  • By Craig_Shipaila
  • joined 29 Feb'24 - 1 message
  • Michigan, United States
Shippy
Sounds like height switches off or bad..not reading all the time usually means a little out of place..try readjusting them to seat closer to mast..If not then ohm out
  • Posted 3 Mar 2024 18:11
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
Muncie, IN, United States
