Overheating
Hello have a h20evo 391. Keeps going into engine protection and also saying the engine temp is high. It sat the entire weekend and soon start it up a buzzer alarms and instantly says the truck is hot. Have no codes displayed besides when it goes to protection mode it shows 204.
I'm a Hyster and Yale tech and stuck right now.
  • Posted 7 Sep 2022 02:56
  • By WhO_dAt
  • joined 7 Sep'22 - 3 messages
  • Michigan, United States
Er reprogram can not connect with display, display also off with key on. Before swap everything works and truck goes on. VSM possible to download the hex package but dash not. Really strange
  • Posted 8 Sep 2022 00:22
  • By tr_doctor
  • joined 4 Dec'20 - 186 messages
  • Netherlands
Regards
Pcst- programming-truck programming- er reprogram
If your asking for the steps in pcst
  • Posted 8 Sep 2022 00:11
  • By WhO_dAt
do you have experience with a Yale A955 electric truck ? I need info how about set a new VSM or Display with PC tool Yale i have.
Regards
  • Posted 7 Sep 2022 23:44
  • By tr_doctor
  • Netherlands
Regards
replace the temp sensor in cooling systeem. If you can measure the temperature of cooland with external measurement and it is not overheat the sensor give bad info. Easyer look in service diagnose wich temperature sensor give to ecm.
  • Posted 7 Sep 2022 23:43
  • By tr_doctor
  • Netherlands
Regards
Yes D204.
The fan goes to high speed as soon as start the truck. Also the temp gage says it will be hot which in fact it is not.
  • Posted 7 Sep 2022 20:33
  • Modified 7 Sep 2022 23:15 by poster
  • By WhO_dAt
You mean a D 204 code , T204 or L204 are different errors.
D204 say engine to hot. Check cooling fan behind engine rotate max speed. It is electric fan and pulsed controlled by the ECM module Linde. If not rotate at max speed ECM defective
  • Posted 7 Sep 2022 17:15
  • By tr_doctor
  • Netherlands
Regards
VETTER Industrie GmbH
Michel Denis Michel Denis
