Hyster E60Z:
steering erradic, error codes
I have a hyster e60z and the steering will all of the sudden quit and then work again. Occassionally get error codes 67 and 51. Anyone with any suggestions as to what the problem may be?
  • Posted 6 Aug 2009 03:13
  • Discussion started by roseypat4
  • Michigan, United States
take the steering sensor off the column ,the motor should go full speed. if not you may have a faulty controller which is the top part of the motor. only way to fix that is to replace it. hopefully you have already checked all the wiring between the column and the motor for kinks and breaks
  • Posted 8 Aug 2009 17:32
  • Reply by kevin_k
Hi Edward the serial on the unit is G108V04548C. Thanks Pat
  • Posted 6 Aug 2009 21:10
  • Reply by roseypat4
a serial number (series) would help in knowing what the possibilities are.
without a serial number I would guess you have a battery and battery corrosion problem. Pull the battery and get all the corrosion out from the area under the battery, and replace any power cables that have been sitting in the corrosion.
Also, while the battery is out, blow the motor and contactor panel clean.
also check the brushes in the power steering motor, if it is not an AC motor, and check the contactor tips
  • Posted 6 Aug 2009 05:39
  • Modified 6 Aug 2009 05:41 by poster
  • Reply by edward_t
Stamford, CT, United States United Rentals has agreed to acquire the assets of family-owned Ahern Rentals for USD2 billion in cash. United Rentals is the largest equipment rental company in the world, with...
Berkshire, United Kingdom UK Material Handling Association is warning against excessive cranking over of the engine and repeated starting attempts for LPG forklifts. This follows recent reports of cold starting issues on...
Inside Forkliftaction
The world's biggest equipment rental company, United Rentals, is about to become even bigger with its acquisition of Ahern Rentals.
This is just the latest in a string of rental acquisitions this year, prompted by rising demand for equipment at a time when supply lines are tight and purchase prices
...Continue Reading
John Lennon had terrible eyesight and was very self-conscious about it. Early in his career, he would not wear his glasses during performances. In the end, John's 'granny glasses' became one of his most iconic trademarks. His last pair, worn on that tragic day in 1980, are kept at 'The Beatles Story' exhibit in Liverpool, insured for over £1 million.
Latest Jobs
Louisville, Mississippi, United States
Springfield, IL, United States
Greenville, North Carolina, United States
Louisville, KY, United States
FOR SALE ON MACHINERY-ONQ
Crown SX3030TT4250
Australia Victoria
United States Pennsylvania
Denmark
Next Editorial Features
FLEET MANAGEMENT - September
CONTAINER HANDLING - November
Safety in operations is gaining increasing attention these days. Potential risks associated specifically with warehouses and production areas are becoming especially apparent at times when goods handling is extremely busy. However, the growing portfolio of safety solutions from Linde Material Handling (MH) can assist.
At 10:00 am on November 18, Heli held the global launch of the new K2 series 5-10 tons internal combustion forklift at its headquarters! Partners from home and abroad sent congratulatory videos on the launch of the new Heli K2 series product.
Your Focus
Stuart Taylor
Stuart Taylor
