Side shifters as clamps
Is it within proper use of side shifters to use it as clamps? I doubt it is but I need it confirmed. Thank you
  • Posted 11 Sep 2017 22:20
  • By dan_e
  • joined 11 Sep'17 - 6 messages
  • Vermont, United States
All of my Crown Rc5500 and 5700 lifts are exactly that with a cascade clamp set up it was plug N play and beyond easy
  • Posted 25 May 2026 03:04
  • By Savigalo
  • joined 25 May'26 - 2 messages
  • NV, United States
A dedicated clamp attachment hydraulically locks when you grip the load. It won't unclamp until it sees hydraulic pressure in the unclamp side of the circuit. Side-shifters don't have this feature.
Sounds like you're talking about fork positioners, not side shifters but the same logic applies. They don't clamp well, and you're probably damaging the equipment using them that way.
You'd probably lose your job but you could offer to call OSHA to decide the question.
  • Posted 20 May 2026 08:20
  • By lumberjack
  • joined 27 Jul'07 - 192 messages
  • Maryland, United States
You are correct to question this. In general, side shifters are not designed to be used as clamps.
The primary function of a side shifter is to move the forks laterally for positioning the load, and the hydraulic cylinders and frame structure are intended for side movement rather than continuous clamping force. Using a side shifter to clamp loads may create uneven pressure, reduce attachment life, and in some cases may cause damage to the cylinders or frame, especially if the load requires regular gripping or secure holding.
For applications where gripping or holding loads is required, a dedicated clamp attachment is the proper solution. Clamp attachments are specifically engineered to provide controlled clamping force and safe load handling for products such as cartons, paper rolls, bales, appliances, drums, and many other non-palletized loads.
This post contains images that are pending approval
  • Posted 18 May 2026 15:11
  • By HuamaiAttachment
  • joined 18 May'26 - 2 messages
  • China
www.huamaiattachments.com-Make Handling Easier
If you go to the Cascade web site you might find some documentation to support this.
  • Posted 15 Sep 2017 06:59
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
Is there any documentation or regulation I can site to my employer so they can force fork lift drivers to stop using it in this way?
  • Posted 11 Sep 2017 22:27
  • By dan_e
Side shifts are not designed to be used as clamps. Mechanically they are not strong enough. The hydraulic circuit is not a clamping circuit so it is unsafe to use it as such.
  • Posted 11 Sep 2017 22:24
  • By BREWSKI
UN Forklift FD50T-NJB3
Toyota 02-8FD30
US forklift tariffs now 15% Washington, DC, United States
edition #1285 - 11 June 2026
