Safety first
On certain makes of truck, the steer sytem is by fixed drag link to the steer axle. If the steered wheels contact a kerb, the force can be transmitted back through the steer linkages and cause the steering wheel to turnrapidly. If a steer **** is fitted, this can cause injury to the driver. With full hydraulic steering , this should not occur.
  • Posted 24 Jun 2004 19:53
  • Discussion started by vic_k
  • Ayrshire, United Kingdom
Anyone using a steering **** on a lift truck must ask one important question first:
Did it come from the factory with a steering **** or was it installed later?
If a steering **** was installed after it left the factory, it could in fact be an alteration or modification and should be approved - in writing by the manufacturer prior to use. If prior authorization has not been received, it is possible that the end user could be liable for it's use.
We need to consider the problems when using a steering ****:
What you'll see in print relates to road feedback or kickback (as stated earlier) of the steering wheel and an operator breaking/injuring their thumb or wrist.
You'll also see in some standards that, steering knobs must be within the width of the steering wheel and operators should hold palm style, not with their hand vertical.
What you won't see in print (usually) is: lift trucks that have a steering **** will cut and turn that much sharper and with rear end swing a steering **** could be a partial cause of a lift truck lateral tip-over.
What you also won't see in print is:
Operators not used to using a steering **** could fail to use it and their hand could hit the steering **** and they could lose control of the steering.
Loose clothing could get caught up by a steering **** and again, cause the operator to loose control of the steering.
Another potential problem - just mentioned to me this week by an operator is that is it could aggrevate or cause a problem with tennis elbow.
Reading the replies on this list gave me one more reason for a potential problem - a head on collision and a **** hitting the operator as they lurched forward (cause they probably didn't have their seat belt on - "tongue in cheek". That's a whole other conversation).
Steering knobs are necessary on one handed steering like narrow aisle stand up rider trucks, but if you have one on a sit-down rider type counterbalanced lift truck, I think it would be wise to review unless it came directly from the factory with a ****.
  • Posted 7 Nov 2004 22:34
  • Reply by garry_p
  • New Brunswick, Canada
The history of the steering **** comes from the highway tractor of the 50's & 60's and were used because some of these trucks took 20 turns of the steering wheel lock to lock, some knobs were 5" high and highly decorative, they were outlawed in some states and provinces because truckers were getting impaled during accidents and also broken thumbs if they lost their grip on the **** when turniing.
I have never seen a law where they were outlawed on industrial equipment though.
However I recommend they be used on forklifts with full hydrostatic steering only and to use only the short fat knobs placed in the 8:00 to 10:00 positions and also to be used by the left hand only.
Avoid the 6:00 and 4:00 to 2:00 positions as this reduces interfence of the big tummy and discourages steering with the right hand.
Regards
  • Posted 31 Jul 2004 13:58
  • Reply by Al_S
  • Alberta, Canada
Alberta Forklift Safety Council
Serious about safety!
Now more than ever, warehouse space is at a premium and increased volume of stock and number of workers share the same space, leading to situations where machines and people come too close for comfort. Technology from Transmon Engineering can assist.
The conference programme for AntwerpXL, the award-winning breakbulk, heavy-lift and project cargo event, has been unveiled.
Featured Business
Zhejiang UN Forklift Co., Ltd
Latest Jobs
Miami, Florida, United States
Dayton, United States
Council Bluffs, IA, United States
Lafayette, IN, United States
Next Editorial Features
FLEET MANAGEMENT - September
CONTAINER HANDLING - November
Latest Jobs
Louisville, United Kingdom
Cat® Lift Trucks has introduced two new flexible work partners as part of its pedestrian warehouse truck range - the Cat® NSP12N2C and NPP12N2D. Their aim: to keep your goods flowing quickly, even in narrow spaces.
For our latest audience statistics, advertising options, editorial calendar and an insight into our latest developments: Download your copy of the NEW Forkliftaction Media Kit here Build your brand...
Featured Business
Durwen Maschinenbau GmbH
Leading supplier of premium, high quality attachments "Made in Germany".
-  Mobicon 2HL Mini-Straddle Carrier 2nd Generation -  Cascade AGV Attachment Solutions -  BSLBATT Lithium Forklift Batteries -  Transmon Engineering Adaptive Speed Control -  OneCharge Forklift Battery Selector Tool Check out the leading product...
Featured Business
Semax Material Handling AB
Unique forklifts from 6-25t that increase safety and efficiency.
Latest Jobs
