ROLL CLAMP HYD. OVERHEATING
The Toyota (8FG50N) forklift that is fixed with a roll clamp, the entire hydraulic system is getting heated up. While working there seems to be some abnormal sound coming from the clamp area and the esp. the control vales fixed on the clamp is getting very hot while in operation.
Can anyone help us to find out the reason why the system is getting overheated?
  • Posted 6 Feb 2026 17:12
  • By Equip_DT
  • joined 6 Feb'26 - 1 message
  • Dubai, United Arab Emirates
I would start by removing the fittings in the block on clamp and checking for restrictions
Then check block , and hyd motor on clamp
A restriction is sometimes very difficult to locate it requires removing and checking presses and return points
It could be in one of the cyl locks also
  • Posted 14 Feb 2026 09:09
  • By John_Bradley
  • joined 10 Aug'22 - 301 messages
Jb69
Restriction is what heats up the oil. Every fitting is a restriction. Is there something online that is not normal ? We have these and run all day long and no issues. Is your attachment flow set to 9 or full on?
  • Posted 13 Feb 2026 10:18
  • By ron_k
  • joined 2 Apr'15 - 140 messages
  • North Dakota, United States
4kliftman
edition #1284 - 4 June 2026
It has been a big week of product launches for the materials handling sector... Continue reading
Lithium Storage
Leading China-based developer and manufacturer of Industrial Lithium Batteries.
