NISSAN MAP1F2A25LV Cam Position Sensor
Hi going to replace the Cam Sensor on a Nissan MAP1F2A25LV. Can I assume everything is metric on these lifts? Also it seems like taking the fan off is going to be the best way to access it, in addition to taking the little panel off behind the seat should I also remove the entire seat / hood or is that not necessary? Thanks in advance for any help! I did buy the OEM sensor!
  • Posted 4 Jul 2026 14:38
  • By Vegastime1
  • joined 13 Dec'18 - 12 messages
Thanks for the reply. I was probably doing it today as you were writing this message. I ended up leaving the hood / seat on and accessing it from the panel behind the seat. Pulled the shroud forward and removed the fan to get to it. Your way sounds easier for sure. I'll know next time!
  • Posted 6 Jul 2026 09:06
  • By Vegastime1
It is easier to access it from the LH rear wheel. If you can turn the wheel somewhat you can gain easy access to both the cam and crank sensor. The bolt heads are 10mm. I've done quite a number of these.
  • Posted 6 Jul 2026 08:08
  • By mwjago
  • joined 20 Apr'25 - 16 messages
  • Montana, United States
mwjago
May CapEx Index falls Washington, DC, United States
November 3-4 2026 - Houston, United States
Tampa Florida, United States
edition #1289 - 9 July 2026
In this week’s Forkliftaction News , we continue our coverage of CeMAT Australia with a report on how the lack of local after-sales support and service is hurting new foreign entrants into the Australian market... Continue reading
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
Toyota 02-8FD25
TCM FD115-3
Linde Material Handling
