mast issues
have a nissan PF50 lift. issue is second stage of mast starts lifting before free lift , have replaced all bearings on the free lift portion of the header as there were some binding. not sure where to look from here
  • Posted 2 Oct 2026 01:45
  • By bkw34
  • joined 23 Jan'18 - 5 messages
  • alberta, -
Your problem has nothing to do with rollers the free lift cylinder as a bad check valve in the bottom of the piston ram or a packing in the free lift cylinder that is bad oil is getting past the packing and is trapped in the head look at that. Hope L was of help.
  • Posted 3 Oct 2026 11:37
  • By Scott_
  • joined 16 May'21 - 349 messages
Scott
